Removing the air pump
Old 01-01-2012, 10:07 AM
s2konroids's Avatar
Default Removing the air pump
Guys,
I'm going to attempt to remove the air pump and associated pipes apart from the relay/connectors and wiring tomorrow.
I am going to test the resistor trick on the stock ECU.
I believe you can remove the pump without taking the front bumper off?
Has anyone removed one?, how easy it is to do? and anything to watch out for/tips?
Thanks in advance.
Old 01-01-2012, 10:10 AM
razzele's Avatar
i think it would be easier to remove the bumper but in my case it is cable tied on for quick release lol
There is only a couple of bolts to undo to remove it but I still think it would be too fiddly and annoying to do like that
Old 01-01-2012, 10:16 AM
s2konroids's Avatar
Yeah your probably right mate
Do you have the remove the undertray when removing the front bumper? - cant remember.
Old 01-01-2012, 10:22 AM
MB
Member
MB's Avatar
No
Old 01-01-2012, 10:41 AM
s2konroids's Avatar
Hopefully the resistor trick will work, and i can banish this CEL light.
Old 01-01-2012, 11:51 AM
Banned
rob2.2's Avatar
i have a delete kit i am hopefully fitting tomorrow (weather depending) and will be doing it from removing the inner arch lining. taking the bumper off is to much hassle
Old 01-01-2012, 11:57 AM
MB
Member
MB's Avatar
I think you will struggle Rob.
Old 01-01-2012, 12:04 PM
D2 TEX's Avatar
I suppose this is something I should look into doing with mine as I think the AEM EMS is capable of deleting it and I don't think its attached to anything on my car at the moment. I take it all i'd need to do is make up a blanking plate?
Old 01-01-2012, 12:16 PM
Banned
rob2.2's Avatar
Im good at struggling, plus with my new under tray/splitter i have fitted removing the bumper is hard work
Old 01-01-2012, 12:22 PM
s2konroids's Avatar
Good man , depending on what kit you have, you can't remove absolutely everything but bulk of the stuff (the only thing you can't remove is the relay and wires).
I need to check what happens when you the vacuum tank and air control solenoid valve, as this could be tricky.
Quick Reply: Removing the air pump
