Full Air Conditioning AC System, (inludes everything) less than 60k, worked great when removed. - 200.
S2000 Factory Radio/CD works perfect. - 60.
AP1 Flywheel 60k miles. (Lightweight upgrade for your AP2) - 80.
Power Window PW Assemblys (driver and passenger) - 125.each
Ap1 Black Door Panels (No rips or tears) - 75. each. or 100. each with switches and trim pieces
Black Carpet in real good shape - 100.
Also Have Switches for Power windows, power top, radio controls, ...etc.
Apexi Neo VAFC in perfect working order, used - SOLD
NRG 6 point Harness with Cam Lock quick release, like new. - SOLD
Roll Bar 4 Point Weld in by Kirk Racing, cut out nicely, does not include base plates(new base plates from Kirk racing are $50-70. or you can make them) - SOLD
Full Set of HOOSIER R6 DOT slicks 245/40/17 used, LOTS of Life left (single pic. tire shows the most wear) Still has lots of tread depth at measuring dimples. - SOLD
Momo Suede Steering Wheel 350mm (stock S2k diameter), Great shape, used with gloves. SOLD
Saner Front Adjustable Sway Bar, includes all hardware and adjustable hiem joint endlinks - SOLD
Science of Speed Aluminum Adjustable Front Upper Control Arms, replaces bushings and balljoint with hiem joints, includes all hardware - SOLD
Set of Enkei RPF1 Wheels (4) 17x8.5 +30 Black 5x114(This is an aggressive offset for the s2000, will require aggressive fender rolling and some camber or if your looking for hellaflush fitment.)(This offset a perfect fit for EVO and some others.) - SOLD
Wheels only - No Tires
Call Brian (615) 397-1772
Attached File(s)
Number of downloads: 13 -
Number of downloads: 15 -
Number of downloads: 23 -
Help
