DFWs2k, on 31 January 2012 - 10:58 AM, said:
Keep us updated with the results, are you just rebuilding with aftermarket parts in an attempt to make it stronger?
Yes, just want to make it stronger. I read too many threads about bent valves and broken retainers. I find this transmission is easy to miss shift and I like to wind it up. Hoping the upgraded valvetrain will give me some insurance. Plus at 81,000 miles, I figured it should all be replaced with the good stuff since it was already out.
I am not 100% convinced that my miss was due to just the valves though. On a compression check I hit 230, 190, 230, 230 (all were 230 3 weeks ago). 190psi in #2 is not good but the motor was missing so bad that it sounded like one cylinder should have 0 psi. So, I would not be surprised if it still misses when I get it back together. If it does, I am thinking it could be a coil pack or fowled plug. Any other ideas on this would be appreciated.
