We are now one of the official dealer for Powerflex bush, I guess most of you know what it is but here is just a small info for someone want more info about the products -
Polyurethane has been with us as a specialised plastic for some thirty years. However recent advances have now made it possible to engineer very special properties into this exciting material. Suspension bushes are some of the most highly stressed components fitted to a motor car. They undergo enormous strains and in the most arduous of conditions with no maintenance or lubrication.
The material they are manufactured from is a rubber compound containing natural products which deteriorate with age. It becomes softer and more pliable, resisting the forces placed on it less and less. Therefore allowing more and more movement of suspension components and offering less and less control over the suspension geometry.
This in turn causes accelerated tyre wear, braking instability and poor handling. This is the single biggest reason you can instantly tell the difference driving a three year old car compared to a showroom new one. However even new cars will benefit from POWERFLEX bushes because of their superior design they offer much more effective control of the suspension components to a much greater extent than normal rubber items.
With the technological advances in this material it has been possible to overcome the common problem associated with harder bushes which is increased noise. By correctly engineering the polyurethane compound, bushes can be made 25-30% stiffer than new rubber items but with exactly the same noise absorbing properties. POWERFLEX bushes make sense.
POWERFLEX for prolonged tyre life.
POWERFLEX for improved performance.
POWERFLEX for increased safety.
Here is the full price list - for S2000
Front Upper Wishbone Bush
PFF25-201 £19.74 inc VAT and you will need 4 per car = £78.96 - S2ki Member price - £70
Front Lower Wishbone inner bush
PFF25-202 - £22.38 inc VAT and you will need 2 per car = £44.76 - S2ki Member price - £40
Front Arm Rear - Front Compliance Bush* New design for S2000
PFF25-203 - £69.54 inc VAT and you will need 2 = £139.08 = S2ki Member price - £125
Front Stainless Steel caster Adjustment kit -
This kit is complete with high tension bolt and comes with high quality stainless steel and work out cheaper than Honda parts.
PFF25-203G - £78.29 inc VAT and will need 2 = £156.58 - S2ki member price - £140
Rear Upper Wishbone bush
PFR25-209 to Fit - 2004 onward S2000 - £23.94 each and will need 4 = £95.76 - S2ki member price - £86
PFR25-210 to fit - 1999 to 2004 S2000 - £19.74 each and will need 4 = £78.96 - S2ki member price - £71
2004 onward -
Pre 2004
Rear Lower wishbone Front Bush
PFR25-211 - £22.38 inc VAT retail and will need 2 - £44.76 - S2ki member price - £40
Rear Lower wishbone rear bush
PFR-25-212 - £22.38 inc VAT retail and will need 2 - £44.76 - S2ki member price - £40
Rear Toe arm bush - Not needed if you have Hardrace rear toe arm fitted
PFR25-214 - £21.06 inc VAT retail and will need 2 = £42.12 s2ki member price - £38
Anti roll bar bush, they have 4 sized available - 25.4mm, 26.5mm, 27.2mm and 28.2mm
All prices are the same £17.10 each inc VAT retail and you will need 2 for each ARB = 34.2 - S2ki member price - £31
Powerflex doesn't do the suspension bottom bush, we can do this from Poly bush -
Front and rear suspension damper bush - £72.8 for all 4 of them.
All available to order now -
full package price inc Poly bush damper bush, Compliance bush adjustment kit will be - £650 inc VAT or £635 for early S2000.
We can do a full fitting for £700 plus VAT
Let me know if you have any question.
thanks
Dixon
This post has been edited by Dixon Motorsports: 02 February 2012 - 12:50 PM
Help
