S2KI Honda S2000 Forums: 120k maintenance - S2KI Honda S2000 Forums
Jump to content
Page 1 of 1
120k maintenance what else needs to be done?
#1 User is offline   oyitzpreston
  • Group: Guest
  • Country: United States
Posted 13 February 2012 - 01:12 AM
Alright just to give you some background my ap1 is currently at 121k I was at the verge of selling my car just because I felt like the s2000 wasnt much an interest to me anymore but a buddy of mine sparked my interest in it again now I decided to keep it and hopefully turbo it in the future. I'm still a broke college student so it'll take me a while to get all the things I want done so right now I just want to make sure my motor will be able to handle the boost with its high mileage. The s2000 is not my daily I drive it on the weekends when I feel like it so down time is not an issue. I have no mechanically issues what so all right now all fluids have been changed diff, trans, engine, radiator. Although I have yet to change my retainers which I am doing within the next couple weeks or so. I'm replacing both the exhaust and intake side and was wondering what else I should replace while I have it opened up and also OEM vs aftermarket. Valveguides, springs,or any seals or gaskets...etc? I searched but didnt come up with anything with much detail. Any links or info would be greatly appreciated!
info on my car not sure if it helps
03 ap1
121k
Parts that have been replace:
clutch master cylinder
slave cylinder
clutch oem (will be upgrading once the car is boosted)
flywheel lightweight competition
spark plugs, fluids, all regular maintenance
mods:
I/h/e
Thanks in advance
#2 User is offline   HondaGuy1212
  • Group: Guest
  • Gender:Male
Posted 13 February 2012 - 09:32 AM
For the retainers, you only need to upgrade the intake side to AP2 retainers/keepers.
Posted Image
#3 User is offline   oyitzpreston
  • Topic Starter
  • Group: Guest
Posted 13 February 2012 - 12:08 PM
I'm doing both sides for a piece of mind
#4 User is offline   dwight
  • Group: Guest
  • Gender:Male
Posted 13 February 2012 - 10:01 PM
From what I've read, only the intake side fails. Just changing things for piece of mind doesn't make sense.
#5 User is offline   oyitzpreston
  • Topic Starter
  • Group: Guest
Posted 16 February 2012 - 08:28 PM
Well it would just make me feel better to know that both sides were changed thats just the kinda person I am the parts are dirt cheap anyways.
#6 User is offline   dwight
  • Group: Guest
  • Gender:Male
Posted 16 February 2012 - 08:46 PM
You could preemptively replace your shift knob. :confused:
#7 User is offline   oyitzpreston
  • Topic Starter
  • Group: Guest
Posted 16 February 2012 - 10:58 PM
If your just gonna be a dick you can go ahead and get the f@#k off my thread. thanks
#8 User is offline   AZ-S2000
  • Group: Guest
Posted 17 February 2012 - 12:09 AM
Assuming it hasn't been done, I would replace the pre-cat O2 sensor. O2 sensors last rated from Bosch 100,000 miles. After than I've heard every thousand miles it loses 2-3% efficiency which leads to poor fuel economy, performance, idle, and the car running rich or lean. AutoZone has the Pre-Cat O2 for 113.00 from Bosch that is an exact fit. I am replacing mine. Im getting bad mileage.
Posted Image
Quote
Well what I put in my s2k is half Shell V-Power and half Chevron with Techron. V-Power + Techron = VTEC! :D
#9 User is offline   dwight
  • Group: Guest
  • Gender:Male
Posted 17 February 2012 - 01:43 AM
I'm not trying to be a dick. My point is that the exhaust side doesn't crack from over reving like the intake side does. If you over rev your motor enough you'll get valve float and bend your valves first way before you can crack your exhaust side retainers.
And, I'm sorry to be the one to inform you of this, but you don't own this thread, so you should learn to play nice.
#10 User is offline   DallasAp1
  • Group: Guest
Posted 17 February 2012 - 01:47 AM
you cleaned your air filter recently? cant think of much maybe valve adjuestment if you havent done one
#11 User is offline   Dingo
  • Group: Guest
Posted 17 February 2012 - 03:45 AM
I would do a valve adjustment. Maybe fluid swaps if you haven't done so. Tranny / diff / and TCT. Brake fluid. Coolant. Pretty much all the little stuff that do the big jobs. I just hit 120ish and my TCT started making noise. So that's 1st on my to do list. Then valve adjustment.
I also think a tune up should be in hand. Plugs. Throttle body cleaning. Maybe even a induction flush. I did one on my engine and it feels like it runs better. A clean motor is a happy motor. :)
#12 User is offline   HarryD
  • Group: Guest
  • Gender:Male
Posted 17 February 2012 - 01:28 PM
+1 If it ain't broke, don't fix it, because you might actually break it :)
Read Billman's response:
Quote
Change intake side only. Using AP2 retainers on the exhaust side will lower the float RPM it takes to bend them. It would defeat the purpose. The idea is to raise the over-rev RPM that can cause hidden damage.
http://www.s2ki.com/...st__p__20565813
Make sense?
Posted Image . . . . . . . . . . . . . . . . . Posted Image
#13 User is offline   oyitzpreston
  • Topic Starter
  • Group: Guest
Posted 17 February 2012 - 10:28 PM
Dwight- I might not own this thread but i started it if you werent gonna contribute anything beneficial then you can just not say anything at all.
But anyways yeah i read billmans threads already so im going with ap1/ap2 retainers it just seems reasonable to go ahead and replace it while im there.
Air filter check
Plugs check
Tranny/ diff check
TCT is on my do to list
What is an induction flush??? Do you mean the sea foam stuff?
#14 User is offline   s2000maniac
  • View gallery
  • Group: Member
  • Gender:Male
Posted 17 February 2012 - 11:14 PM
Air filter check
Plugs check
Tranny/ diff check
who is doing the retainer swap for you?
9k ALL THE WAY!!
Posted Image
#15 User is offline   HarryD
  • Group: Guest
  • Gender:Male
Posted 19 February 2012 - 08:58 PM
Off the top of my head... Here is what you should do to make your car run like new (read the manual + diy's for these):
  • valve adjustment (and do the retainer swap according to Billmans instructions)
  • Replace your TCT with billmans modified (do the core exchange) if and only if you have the ticking symptoms
  • diff fluid change
  • tranny fluid change
  • regrease + sand-down your clutch slave (http://www.s2ki.com/...y-clutch-pedal/)
  • regrease your shifter (http://www.s2ki.com/...se-shifter-diy/)
  • change your brake fluid
  • change your clutch fluid
  • oil change
  • techron treatment and/or seafoam (before oil change)
  • clean your throttle body
  • clean your IAC valve
  • replace PCV valve
  • re/adjust your throttle cable (back into spec)
  • alignment + proper tire pressure
  • change air filters (cabin + intake)
  • brake pads/rotors/etc. as needed
  • spark plugs! (use the OEM ones)
  • buy HarryD a beer
This post has been edited by HarryD: 22 February 2012 - 12:11 PM
#16 User is offline   oyitzpreston
  • Topic Starter
  • Group: Guest
Posted 19 February 2012 - 11:15 PM
[/quote]who is doing the retainer swap for you?
[/quote]
I have no idea yet I am still debating if I want to attempt to do it on myself with someone that has done it before or just find a shop I can trust ive had some bad experiences with shops in the past so most likely will be attempting it on my own. I have the manual already and will be using the DIY thread.
#17 User is offline   oyitzpreston
  • Topic Starter
  • Group: Guest
Posted 19 February 2012 - 11:16 PM
  • diff fluid change
  • oil change
  • replace PCV valve
  • buy HarryD a beer
Thanks for the help come down to TX and youll get your beer!
#18 User is offline   morrobaybum
  • Group: Guest
  • Gender:Male
Posted 21 February 2012 - 05:09 PM
Dont forget your upkeep for the interior and exterior of the car too! The s2k looks sexy even though its 12 years old! A little bit of 303 on the soft top makes it look like brand new.
Posted Image
#19 User is offline   HarryD
  • Group: Guest
  • Gender:Male
Posted 22 February 2012 - 12:12 PM
I also added spark plugs to my list.
And +1. I bought the Lexol leather cleaner, conditioner, and vinyl cleaner kit from Amazon:
http://www.amazon.co...29930715&sr=1-2
My seats look much better after I clean + condition them and vinylex the dash and vinyl trim!
#20 User is offline   riceball777
  • Group: Member
  • Gender:Male
Posted 23 February 2012 - 12:01 AM
http://www.s2ki.com/...5#entry21423195
my brother just bosted his s2000 with 160k miles and its been running great
501whp @17 psi
my turbo s2000
http://www.s2ki.com/.../#entry20952158
#21 User is offline   AZ-S2000
  • Group: Guest
Posted 23 February 2012 - 04:13 AM
Again, if your nearing 100,000 miles change the Pre-Cat Oxygen Sensor, not post cat. You should notice a better experience (efficiency, power, and mostly fuel economy)
Ads by Google   S2KI
Share this topic:
Page 1 of 1
