FS: Breaking MY2000 car all parts available. Silverstone Silver.
#26
Posted 02 March 2012 - 04:25 PM
MY00 S2000 on 17" Rota Force '259.9hp, 153lb/ft'
#27
Posted 04 March 2012 - 05:16 AM
not sure if they are handed or identical side to side, the one I need is off-side/drivers
#28
Posted 04 March 2012 - 01:42 PM
Αν αγαπησεις αυτο που κρατας στα χερια σου, θα γινει ο καλυτερος φιλος σου.
Αν δεν το σεβαστεις ... θα σε σκοτωσει !!!
#30
Posted 11 March 2012 - 04:13 PM
Full red leather seats: £335 COLLECTED ono
Drivers
http://i7.photobucke...-t/IMG_1274.jpg
http://i7.photobucke...-t/IMG_1270.jpg
Passenger
http://i7.photobucke...-t/IMG_1299.jpg
OE rear brace(boot area): £30 delivered
http://i7.photobucke...-t/IMG_1285.jpg
Rear brake discs and EBC Red Stuff pads, part worn(circa 2000miles). With a part worn set of Ferodo DS2500 included. £85 delivered.
http://i7.photobucke...-t/IMG_1283.jpg
Rota Blitz 17"
Meister Zeta R coilovers
Megan rear toe links
Front rack raisers
Front and rear Cusco lower braces
Buddy Club Spec 4 exhaust
decat
K&N Typhoon
HEL brake & Clutch lines
Recaro Profi SPG
#31
Posted 12 March 2012 - 06:44 AM
Dan
#32
Posted 12 March 2012 - 08:02 AM
#33
Posted 13 March 2012 - 11:34 AM
#36
Posted 15 March 2012 - 03:20 PM
£260 delivered for the Diff
£75 delivered for the Prop
#38
Posted 28 March 2012 - 03:10 AM
OE exhaust header(upper heat shield will be included), with Lambda sensor. £55 delivered
Air con radiator. £65 delivered (I also have the air con hoses and front hard pipes if required)
#39
Posted 28 March 2012 - 03:53 AM
#40
Posted 28 March 2012 - 07:11 AM
#41
Posted 01 April 2012 - 11:57 AM
Steering ECU. £45 delivered ono
#42
Posted 08 April 2012 - 04:00 PM
Door sill trims, £20 delivered.
Black dash is ready to go. £85 delivered.
Single drive shaft(with the bolts). £45 delivered.
Front slam panel crossbar bit, silverstone silver. £25 delivered.
#43
Posted 19 April 2012 - 02:07 AM
Passenger side front hub with ABS sensor. Ball joint thread is a bit damaged but still useable, and ball joint itself is fine. £50 delivered.
Windscreen/roof surround rubber seal. part number 1 in this picture Excellent condition. £70 delivered
Clutch master cylinder £50 delivered
Clutch hard line(from MC to Slave)- £20 delivered
Open to offers on ALL parts listed.
#47
Posted 02 May 2012 - 11:23 AM
Cheers
Tim
#48
Posted 03 May 2012 - 01:35 PM
I've also got these bits for sale-
PIAA horns £20 delivered
Coolant expansion tank £15 delivered
Inlet hose £15 delivered ono
Drivers side front hub with ABS sensor(NO ball joint) £50 delivered
Aircon tank thingy that sits at the front £15 delivered
Help
