Suspension / Geo / Drive question, I have an issue. ***SORTED***
Posted 17 February 2012 - 02:19 AM
I had previously had a Fast Road Set-up applied to it, rather mild settings, nothing too aggressive (I have the readout if it helps).
I requested to have the geo checked while the car is there just for good measure. Everything was fine, no need for adjustment. I believe this was carried out after the parts where fitted.
Brand new tyres too fitted about 80 miles ago (452's on V2 OEM 17"s).
Everything feels fine on the way home until I hit the motorway.
Under hard acceleration, the car sort of drives to the right a bit, not so much pulls, as if it's the front wheels, but sort of leans over to the right which you need to correct, (very slightly).
Also, manoeuvring at motorway speeds (changing lanes) feels very skitty, almost twitchy and almost on the edge. Very far from the planted solid feeling I was used to.
Needless to say, this far from ideal and reduces confidence in the car.
Two questions;
Firstly, would having these parts changed affect the geo ?? Without touching the camber adjusters ??
Secondly, to my eyes, the passenger side rear wheel is pushing significantly more - camber than the driver, I may be wrong here as it was fading light, but would this result in the above symptoms ??
I'm going to call my tuner today and have a chat, who I'm sure will sort it out, but I'm keen to listen to anyone that may have an idea as to WTF is going on !!
Posted 17 February 2012 - 02:25 AM
Fitting hubs etc takes it all apart so it will effect the geo
Posted 17 February 2012 - 02:38 AM
WinFreak, on 17 February 2012 - 02:25 AM, said:
Hmmm, that would be your (and my initial thought) but I doubt that.
Now this I wasn't sure of, if that is the case, then hopefully it's an easy fix of just getting it reset, however, I'd be shocked if this was overlooked and not noted.
Have to get it sorted soon I've got a Spa track day in April !!
Posted 17 February 2012 - 02:48 AM
There is almost no way you could put all that back together and retain the original Geo although there is no hub adjustment so unless they moved something when removing the old hub it 'should' go back almost within tolerance.
What about drive shaft bearings, is it possible that one is now more worn than the other and it's messing with the diff? Have they tightened the balljoints up properly? What about droplinks?
Why you do not want to order ANY of your S2000 parts from ANY UK Honda Dealer
F3Ang - "No it was surprising easy i had read on the forum about pulling it off when warm"
Posted 17 February 2012 - 02:59 AM
Did you give them your print of the last geo adjustment?
Posted 17 February 2012 - 03:02 AM
Suits, on 17 February 2012 - 02:39 AM, said:
Still they should have given you a printout of the current Geo setup. They did all the work to put the car in a Geo maschine without making a printout? I believe they didn't bother at all plus i agree with the hub removal and the Geo with the above members.
Posted 17 February 2012 - 03:27 AM
I'm going to call them soon and have a chat about the possibility of the Geo being overlooked.
I'd much rather that be the case than anything else wearing unevenly or anything like that.
Posted 17 February 2012 - 04:50 AM
Very appologetic and was keen to get me back ASAP to get it sorted out.
The geo was checked, and all was in range, but it will be checked again.
I'll report back with what was discovered.
Posted 21 February 2012 - 02:04 PM
It appears that altering the hub, DOES affect the geo, even though the adjusters weren't touched. Perhaps it's newer designed hub that has been adjusted slightly over the older ones, or, it's bent. lol.
This is what it was....(no wonder it was driving like a pig)
This is what it was set back too.
Nice. All fixed and drives wonderfully.
Posted 21 February 2012 - 02:15 PM
Posted 21 February 2012 - 02:50 PM
kim-s2k, on 21 February 2012 - 02:15 PM, said:
Yeah, far from my ideal, it's a 170 mile round trip, but the owner is a good mate and helped me on many a (Oh Shit !) occasion over the many years I been taking my Honda's there.
Just happy its sorted to be honest and I can prepare for Spa again.
Posted 21 February 2012 - 03:18 PM
Who knows but numbers look much happier as are you
Posted 21 February 2012 - 03:19 PM
Posted 21 February 2012 - 06:55 PM
"I appear to have bought an £86,000 Caterham" Evo 02/06
From Jeremy Clarkson
"This is not a car you need. It is not even a car you want. It’s a car you simply have to buy."
"I'd rather be in this vantage roadster than in Keira Knightley."
Posted 22 February 2012 - 01:37 AM
mikey k, on 21 February 2012 - 06:55 PM, said:
Clearly having a thicko moment - it can't have been checked the first time though, at least not properly ... maybe it just 'looked' right. I'd also bet money that someone who didn't know the car or how to drive wouldn't have noticed the difference on a short test drive.
Posted 22 February 2012 - 02:20 AM
unclefester, on 22 February 2012 - 01:37 AM, said:
To be fair, the issues were only noticeable at motorway speeds and cruising, or changing lanes.
I even took the car out on a test drive and it felt 'alright' on the little link B roads. Although as soon as I got on the motorway it was terrible.
Still, shocking to let a car go out like that really.
#21
Posted 22 February 2012 - 02:40 AM
#22
Posted 22 February 2012 - 04:39 AM
unclefester, on 22 February 2012 - 02:40 AM, said:
Or that, yes.
There are a few reasons that could explain it, but to be honest, I don't care anymore, I'm just happty it's fixed
#23
Posted 22 February 2012 - 06:43 AM
It maybe placebo effect but I was sure that I could feel a misalignment after changing my shafts.
Uncomfortable, Impractical, Unruley and Pointless
Too Fast For The Road, Too Loud For The Track
A Car Worth Much Less Than The Sum Of Its Parts
A COMPLETE WASTE OF TIME AND MONEY
Which Is Exactly Why You've Got To LOVE IT!!!
#24
Posted 22 February 2012 - 01:24 PM
#25
Posted 22 February 2012 - 02:46 PM
Also you can measure twice in a row & get different results. But that rear toe was lethal! Fail.
Is it any wonder that the Honda S2000 has been hailed by perceptive drivers as a new paragon of roadworthiness, considering that the distribution of its masses..........L J K Setright
The power of accurate observation is commonly called cynicism by those who have not got it.......George Bernard Shaw
Ever since September of 2008, we have seen the fruits of the fiat money roots that Mises warned against almost a century ago. But modern free-market economists are as hostile to Mises's theory of the business cycle as they were hostile to Mises's theory of the economic irrationalism of socialism . . . until the Soviet Union fell. Then, they got religion, but they still never mention Mises. It was as if he had never lived....Gary North
Give a man a gun and he can rob a bank, but give a man a bank and he can rob the world - unattributed.
Help
