S2KI Honda S2000 Forums: Coil pack faulty? - S2KI Honda S2000 Forums
Jump to content
Page 1 of 1
Coil pack faulty?
#1 User is offline   champion_hero
  • Group: Member
  • Gender:Male
  • Country: United Kingdom
Posted 19 February 2012 - 12:00 PM
So, as per my other thread earlier this week regarding injector cleaning tto combat my mysterious misfire issue, I thought that seeing as I was already under there, I'd inspect the plugs and coils to be on the safe side, as well as giving the plugs a little clean.
To my horror, I found that the 3rd coil pack seems to be coated in rust and carbon!?
Posted Image
You can clearly see the difference been coil pack 2 and 3 in the picture below:
Posted Image
I inspected the cylinder where the pack plugs in and found it to be very very black, rough and covered in carbon, with a rust like substance around the entrance threading:
Posted Image
Compare this to number 4:
Posted Image
The plug itself seemed to have very little carbon build up on the tip, looking almost unused, whereas the base was very dirty. All other plugs looked more or less the same, with an even coating on the tip.
Posted ImagePosted Image
Is this a sign that the coil is bad, or something more serious?
Once plugged back in, I started up and lifted the packs out as much as I could one by one to test, but couldn't really hear a difference. Perhaps I didn't lift them far enough as I was fearful of shocks.
Any ideas? Should I be concerned? Is it possible to clean down where the pack plugs in?
The car past its mot last week so it's an odd one...
Any help appreciated.
Thanks
Jamie
#2 User is offline   GaryB
  • Group: Member
  • Gender:Male
Posted 19 February 2012 - 12:05 PM
To me it looks like the plug hasn't seated properly and you're getting blow by. Clean the coil packs up, get new plugs and run it for a few hundred miles.
Was that plug loose?
Posted ImagePosted Image MY99 Silverstone S2000.
Wheels, tyres and brakes: 17" gunmetal Rota torques. Continental Contisport 5p's all round. HEL brake hoses
Chassis: Front and rear lower braces, Front upper brace for leaning on at oil change time, full polybush kit, Meister R coilovers.
Engine and engine bay: Tegiwa brake master cylinder brace, Racelogic traction control, PRM intake,
Interior: Qube white dash kit, LED interior bulbs, Alpine HU with bluetooth, 2004 MY door cards with Alpine component speakers, Alpine rear roll bar speakers, 4 channel amp, CG Lock
Exhaust: HKS Silent with de-cat.
#3 User is offline   GaryB
  • Group: Member
  • Gender:Male
Posted 19 February 2012 - 12:08 PM
And what's with the rubber gloves ya wuss? ;)
#4 User is offline   richmc
  • View gallery
  • Group: Member
  • Gender:Male
Posted 19 February 2012 - 12:15 PM
That looks like a LOT of gap on the plug. Try changing the plugs and if thats the only crap looking coil pack change it too. Leave it for 2000 miles and have another look.
Posted ImagePosted ImagePosted Image
It is a fact that 50% of people are of below average intelligence.
Posted Image
#5 User is online   unclefester
  • Group: Member
  • Gender:Male
Posted 19 February 2012 - 12:16 PM
What he said .... both posts haha
Yes this is the space where a signature should be and no, this is not a signature.
Why you do not want to order ANY of your S2000 parts from ANY UK Honda Dealer
Posted Image
F3Ang - "No it was surprising easy i had read on the forum about pulling it off when warm"
#6 User is offline   F3 ANG
  • View gallery
  • Group: Member
  • Gender:Female
Posted 19 February 2012 - 12:41 PM
:iagree: that plug has not being seated , I'd run a thread cleaner down that plug hole and change the plugs,
Everyone's mad except me.
#7 User is offline   GaryB
  • Group: Member
  • Gender:Male
Posted 19 February 2012 - 12:44 PM
And the plug not seating is probably the cause of your misfire....
#8 User is online   gbduo
  • Group: Member
  • Gender:Male
  • Interests:Engineering, ships, F1, cars, hovercraft, sailing.
Posted 19 February 2012 - 01:14 PM
Yeh that gap is huge, I think it should be 0.7mm?
#9 User is offline   F3 ANG
  • View gallery
  • Group: Member
  • Gender:Female
Posted 19 February 2012 - 01:24 PM
Plug gap should be 1mm to 1.1mm A used plug when you take it out can be anything up to 1.3mm ( still within limits for a used plug)
#10 User is online   gbduo
  • Group: Member
  • Gender:Male
Posted 19 February 2012 - 01:32 PM
:thumbup:
Thanks for clearing that up!
Graham
#11 User is offline   champion_hero
  • Topic Starter
  • Group: Member
  • Gender:Male
Posted 19 February 2012 - 01:40 PM
Hmm thanks for responses guys. Will have to take them out again and check the gap then. Oddly though they were only replaced under a year ago by TGM. Tom put in iridium plugs as he believes they are better... I'd be rather surprised if he got them wrong.
The gaps mentioned above, are these the official gap sizes?
#12 User is offline   F3 ANG
  • View gallery
  • Group: Member
  • Gender:Female
Posted 19 February 2012 - 01:50 PM
Yes as per service manual,,,,, Tom will have put them to the correct gap but as the plug was loose it will have being firing different than the rest, so will have burned the tip more, make sure they are seated when you refit measure from the top of the plug to the rocker cover edge, just to make sure No3 is in correctly, if it isn't don't force it get the thread cleaned on the head I'd still bin those plugs though.
#13 User is online   s2konroids
  • View gallery
  • Group: Member
  • Gender:Male
  • Country: Micronesia
  • Interests:Your lass!
Posted 19 February 2012 - 02:13 PM
Agree with above, don't gapp iridium tips you can break them or worse fail inside the cylinder.
324BHP per ton, tuned and installed by AJI.
AJI|Comptech|Swift|Autogauge|Muz|Ricks|SOS|3M|Modifry|Autoleads|Powerflex|Mugen|Alpine|Tracysports|T1R|Honda|Rota|5Zigen|Titan|JVC|JBL|Greddy|Innovate|Heel&Toe
Posted Image
#14 User is offline   champion_hero
  • Topic Starter
  • Group: Member
  • Gender:Male
Posted 20 February 2012 - 02:16 AM
I was checking the pictures I took and the model that have been put in are Denso iridium sk22. According to Denso's website, the sk22 are for the Accord!? The gap and the heat rating are the same, but there must be something different about them or why else sell an alternative. So I've ordered a set of the ngk platinum from opie oils (£36).. I can't imagine ill notice the 1-2 HP from the ngk iridium to justify the price, and hearing stories of tips dropping, as well as the above has made me paranoid now. Thanks for noticing that guys.
I've also ordered a thread chaser and a pipe brush to clean in there (will leave plug in when cleaning) ^_^
#15 User is offline   GaryB
  • Group: Member
  • Gender:Male
Posted 20 February 2012 - 06:26 AM
A good clean with the old plug in place and then a few good squirts with an air line to blow the crap back out. (While wearing eye protection as you'll end up with a face full of it)
#16 User is offline   F3 ANG
  • View gallery
  • Group: Member
  • Gender:Female
Posted 20 February 2012 - 02:10 PM
Remember when using a thread chaser in the plug hole to coat the chaser in grease, any debris will stick to the grease rather than dropping into the cylinder
#17 User is offline   WinFreak
  • Group: Member
  • Gender:Male
Posted 20 February 2012 - 02:14 PM
Might be worth sticking a vacuum cleaner on the end after to try and suck out any crap that still falls in?
Posted Image
Posted Image
Ads by Google   S2KI
Share this topic:
Page 1 of 1
