Flickering dash and electrical problems
Posted 20 February 2012 - 05:44 AM
I've had the battery replaced as it is a halfords one in warranty. Their battery test indicated it was the battery at fault. It worked fine for a bit then the same thing. Again it was replaced as the battery test indicated it as the cause. My local garage has tested the alternator which is good.
It seems to start OK.
Yesterday, however, the alarm went off when I started it and didn't disarm for ages. It's not done this before. I had a similar problem with my MR2 when the battery went dead in the snow and I had to get a garage to kill the alarm.
Is there something shorting somewhere to drain the battery and cause these electrical problems? Has anyone had anything similar?
Posted 20 February 2012 - 06:38 AM
Most weirdy electrical issues tend to be caused by a dodgy earth in my experience.
MY99 Silverstone S2000.Wheels, tyres and brakes: 17" gunmetal Rota torques. Continental Contisport 5p's all round. HEL brake hoses
Chassis: Front and rear lower braces, Front upper brace for leaning on at oil change time, full polybush kit, Meister R coilovers.
Engine and engine bay: Tegiwa brake master cylinder brace, Racelogic traction control, PRM intake,
Interior: Qube white dash kit, LED interior bulbs, Alpine HU with bluetooth, 2004 MY door cards with Alpine component speakers, Alpine rear roll bar speakers, 4 channel amp, CG Lock
Exhaust: HKS Silent with de-cat.
Posted 20 February 2012 - 06:53 AM
Posted 20 February 2012 - 12:18 PM
I used to own FIATs...
You might also want to check the bundle of earthing straps bolted up the driver's footwell, if it's purely dash-related.
Is it any wonder that the Honda S2000 has been hailed by perceptive drivers as a new paragon of roadworthiness, considering that the distribution of its masses..........L J K Setright
The power of accurate observation is commonly called cynicism by those who have not got it.......George Bernard Shaw
Ever since September of 2008, we have seen the fruits of the fiat money roots that Mises warned against almost a century ago. But modern free-market economists are as hostile to Mises's theory of the business cycle as they were hostile to Mises's theory of the economic irrationalism of socialism . . . until the Soviet Union fell. Then, they got religion, but they still never mention Mises. It was as if he had never lived....Gary North
Give a man a gun and he can rob a bank, but give a man a bank and he can rob the world - unattributed.
Posted 21 February 2012 - 04:14 PM
Posted 09 March 2012 - 05:20 AM
Where in the drivers footwell are these serving straps? If I pull back the carpet, is it obvious?
Posted 09 March 2012 - 05:33 AM
These earthing straps are behind the plastic cover on the right hand side of the drivers footwell next to the ECU. You have to remove this plastic cover to locate it which is easy but tricky. There are many earth points-joins in the car. I do not know if the one in drivers footwell is the one responsible for your flickering dash problem
Posted 09 March 2012 - 05:36 AM
Why you do not want to order ANY of your S2000 parts from ANY UK Honda Dealer
F3Ang - "No it was surprising easy i had read on the forum about pulling it off when warm"
Help
