Lots of gas in oil AP1/Castrol Edge 5w30
Posted 21 February 2012 - 10:40 AM
Posted 21 February 2012 - 11:53 AM
Posted 21 February 2012 - 12:02 PM
Bad rings is about the only way aside from valve stem seals or valve guides on the intake side that it can get into the oil.
Posted 21 February 2012 - 07:38 PM
At BITOG, I have heard this called the "Soccer Mom Effect". Soccer moms will sit at theri kid's soccer game with their engine running, causing excessive fuel dilution. Lots of cold starts and no long highway runs will contribute to this as well.
Posted 21 February 2012 - 07:54 PM
Keepers and retainers have no effect on fuel in oil, it would be more related to blow-by and rich fuel mixtures. I'm willing to be you are fine, but have your used oil analyzed, it's the only way to know.
This post has been edited by JFUSION: 21 February 2012 - 07:55 PM
Posted 21 February 2012 - 10:12 PM
Hickey322, on 21 February 2012 - 10:40 AM, said:
Why would you think it's your keepers or retainers? Please explain your logic.
This post has been edited by RedY2KS2k: 21 February 2012 - 10:13 PM
Posted 22 February 2012 - 02:30 AM
And then, when Soccer Mom's car does get on the highway, like going on a holiday or a weekend trip, they find themselves with low oil level at the first fuel station.
All the fuel and water has evaporated, it was keeping the oil level "normal" during the week.
Assuming Soccer Mom's husband checkes the oil every now and then
So.. next time OP goes for an oil change: drive for at least an hour / 60 miles, get some temp in the engine & oil.
Change oil & smell.
A quick & easy valve stem seal check: warm engine, accelerate in 2nd / 3rd to redline, then engine brake to idle revs, get back on the throttle and look for blue smoke in rear view mirror.
Retainers and keepers have nothing to do with this.
AP1: Turn in, DON'T LIFT and hope it sticks.
On Advan AD08's it always does though!
Posted 22 February 2012 - 10:44 AM
I do not idle the car for long periods of time. My car used to burn a lot of oil (2 qts+ between changes with Mobile 1), but since I've switched to Castrol Edge it burns less than a qt between oil changes.
I plan to send the oil for analysis next oil change. I have the oil from my last change in my oil container, would sitting for two months in the plastic container affect the results? I will also try the valve stem check that Spitfire suggested.
Thanks again everyone!
Posted 22 February 2012 - 10:12 PM
Good idea on the oil analysis. You can still send in your sample, it might have a high silicon content from dust and dirt the oil may have picked but I wouldn't worry about it.
Don't stress about the retainers on this car, as long as they haven't been abused they can last the life of the vehicle. It's a good idea to inspect them if you aren't the original owner.
Posted 23 February 2012 - 05:38 AM
1988 WS6 Formula Firebird (totaled)
1997 SS camaro (sold:()
2001 Black/Black S. (DailyDriver)
Now:
Posted 23 February 2012 - 07:23 AM
If the mpg is not much worse than what OEM cars get (search for it) it could all be normal.
Are we talking about the "2010-Current MY02 GPW/red, black door inserts, invidia n1 + test pipe" in your sig?
So you're running without sec. O2 sensor and with a CEL fix?
I've seen many posts of people noticing gas smell out of the exhaust with a test pipe.
So maybe the test pipe & constant sec. O2 value changes how the ECU thinks the engine runs, making it run extra rich?
The prim. O2 and ECU decide the fuel mapping, ect. depending on the throttle input - as far as I know - but who knows what the sec. O2 exactly does?
I've been running with a faulty sec O2 for a while (DD - 130 km a day) and did notice a slight change in fuel consumption, as in, it went up.
Does the old oil still smell like gas, even after sitting for 2 months?
If it doesn't a UOA of that old oil probably would show less dilution / flashpoint change.
Air filter/sparkplugs is/are in good condition?
(basically normal maintenance)
And yes, a 1500 mile OCI is kinda short, but I assume you did this to investigate?
Posted 23 February 2012 - 09:19 AM
I've decided to send the old oil and oil currently in my car for analysis. Is there a company someone recommends, or is that something typically done local? Thanks everyone this is a big help!
Posted 23 February 2012 - 11:42 AM
Posted 24 February 2012 - 10:50 AM
slalom44, on 23 February 2012 - 11:03 PM, said:
So how do people get away with running a TP with the CEL fix? I plugged my o2 sensor into the CEL fix, which goes into the TP. It could very well be the problem, but so many other people do this too. Do they all run rich? And if I continue, will it cause harm to my engine?
#22
Posted 24 February 2012 - 08:43 PM
#23
Posted 24 February 2012 - 09:16 PM
BTW, the OP still has no evidence of his car running rich. Unless you check the plugs, get an air-fuel reading, or analyze your used oil there is no reason to believe the car is running rich solely based on oil "smell".
This post has been edited by JFUSION: 25 February 2012 - 09:14 AM
#24
This post has been edited by Hawkeye_AP1: 24 February 2012 - 09:16 PM
#25
Posted 25 February 2012 - 06:01 AM
Hickey322, on 21 February 2012 - 11:53 AM, said:
Gasoline has a very strong distinctive smell. It doesn't take much in the oil to smell it. If you want to know how much is getting in your oil (fuel dilution %) and whether it's normal, then you'll have to do oil analysis. I would not recommend using Blackstone Labs for tuning your engine. Their method for testing fuel is not accurate enough for this purpose. I would recommend Polaris Labs or Dyson Analysis. Polaris will give you the more accurate data you need, but you'll have to interpret the data yourself. Dyson will give you all the data you need, plus a professional interpretation if you want it.
Good luck!
Help
