Mobil1 Oil leads to brittle guides
So this story goes back to my BMW when I first got it. On my 540i I replaced the guides because they go out like crazy on those. I am a student at my university in automotive engineering and so a few friends decided to test oils on plastics to see what affect they have. We leave the timing guides in the oil, cycle them through temperatures for a long period of time. I think we're close to a year. Than remove the plastic pieces, than set them up for tension testing. Basically the guide in Mobil1 broke first, followed by Penzoil, Valvoline, and than Castrol tested the best. This was further confirmed when I called the dealer and was advised not to use Mobil1 because its bad for timing guides. Keep in mind the BMW guides were a lot thicker (4L V8) than the Honda ones. Just an FYI
Correct me if I'm wrong, but aren't timing chain guides only "splashed" with oil and not "immersed"? Would this not change the outcome a great deal? What viscosity oil are we talking? Is it one sample per oil? How much of a difference did it make? Are you testing ultimate strength? Yield strength? Did it matter? What sort of machine are you using to test the strength? Was there a control? How about conventional oil? What temperatures are you cycling it between?
Not trying to piss on your parade, but I'd really like to know!
This goes back to the thought of never owning a BMW out of warrenty. Yes, some screwed together right at the factory, but some aren't. Also, BMW does not, can not adequately test their motors the way they should for longevity in every market. Every two or so years they come out with new motors across the board, each is somewhat different from the one before. Most designs are good, few are bad, most have great engineering design, but a few a have poor choice of materials where some of those materials fail when used with fuels or lubricants from places other than Germany. Whether it be plastic impellers or the wrong material used in an engine block, it is just smart to avoid an old BMW (5 years or older) if you can.
My favorite BMW experience with this was with my V8 5 series:
http://www.usautoparts.net/bmw/engines/nikasil.htm
Luckily I traded that car in on my S2000 when I felt some cold startup issues at 80,000 miles. Several weeks later the motor needed replacing.
Yes BMWs are great to drive, but when they get old, you better have some sort of extended warrenty.
edit:
When I switched from conventional to synthetic in that car, it leaked from every orifice. It probably needed 6 visits to the dealer to fix the leaks (under warrenty)
edit:
edit:
edit:
Oh sorry.. We used 5W-30 Synthetic (most common oil used) and we have another set going just to make sure our results are the same. The guides surface what the chain rubs on is strong but eventually the chain wears that surface and oil goes into the pours. And to be fair, the way we were setup to test puts these far past 100,000 miles mark
Interesting results. However I've used Mobil One for as long as I can remember in my Integra (290,000 miles) and it performs flawlessly. Likewise I've been happy with it in my S2000 and don't plan on changing any time soon.
