AP1 tranny vs ap2 tranny which is stronger?
Posted 22 February 2012 - 10:11 AM
Posted 22 February 2012 - 02:44 PM
The secondary reduction gear is shorter, along with the first 4 gears which makes the ap2 transmission feel like an ap1 transmission with a 4.3 final drive gear.
The last 2 gears on the ap2 transmission is taller however.
Also carbon syncros on the ap2.
Note: this is all from what I have researched in the past 2 months. I've been thinking about a swap from ap1 to ap2 too.
Posted 22 February 2012 - 02:55 PM
199.8 stock whp on a dynojet
SADD Coalition - S2kers Against Door Dings
...I bought a four banger instead :p
Posted 22 February 2012 - 03:01 PM
starchland, on 22 February 2012 - 02:55 PM, said:
This is true dependent on how much power you will be making. shorter gears are not necessarily bad on a boosted S2K, I believe Sideways posted which gears are optimal at what horsepower rating.
Posted 22 February 2012 - 11:37 PM
Gears 1-4 are actually the same exact ratio as the AP1, and gear 5 and 6 are a little taller...
BUT the different primary reduction gear makes 1-5 effectively shorter (5 is VERY close) and 6th is taller.
Posted 22 February 2012 - 11:43 PM
2007 Civic Ex - Current
2008 CBR600RR - Current
Posted 23 February 2012 - 09:34 PM
Berk Technology 63.5mm Test Pipe, AEM V2 induction system, Ingalls STiFFY Torque Damper, Skunk2 suspension
Posted 24 February 2012 - 05:53 PM
hypforlife32, on 22 February 2012 - 11:43 PM, said:
the syncros do just that...they syncronize the speed of the input shaft with the rest of the transmission so that the gears engage easily. Yes, a carbon syncro would stand up to more abuse...but only when SHIFTING.
They don't hold the power/torque load...that's the gears, shafts, and transmission case, and for all intents and purposes, they are the same transmission in that respect.
Posted 25 February 2012 - 08:16 AM
Study the pics and you will see it. AP2 trans on left. Also take note of the rusted spline on the right trans. #1 cause of notchy shifting, hard shifting, and gear grinds, right up there with dirty clutch fluid.
DaveOnLI....RIP till we come together again....
Volks 16" CE28N , 04 trans, 04 driveshaft, 04 dif, Fujitsubo Exhaust, Rick's 6plus header, T1R test pipe, Comptech: icebox, flywheel, oldschool silver STB, rear tie bar, ACT PP, Billman's shortshifter, Billman's lifetime Gen3 TCT, aluminum pulleys, race pedals
Help
