Sponsor S2000 Engine and S2000 Drivetrain Deals Sponsor deals on S2000 engine and S2000 drivetrain products
Haltech Platinum PRO Plug In ECU for Honda S2000 AP1! MVP Motorsports
Old 02-24-2012, 09:52 AM
Chops@MVP's Avatar
Default Haltech Platinum PRO Plug In ECU for Honda S2000 AP1! MVP Motorsports
Features:
 Direct plug and play replacement of the OEM ECU, no re-wiring necessary.
 Uses the cars factory sensors
 Supports Honda_s VTEC Control
 Supports Sequential Injection (peak and hold) and Direct fire ignition
 Windows 2000, XP, Vista, Windows 7 compatible software
 Real time programming, instant hesitation free adjustment while engine is running
 Fully user definable 32 x 32 mapping
 Tuning via Volumetric Efficiency (VE), Injection time or Lambda Correction (MAF)
 Diagnostic trouble code storing & Check engine light control(Access through laptop only )
 Selectable onboard internal MAP sensor rated to 150kPa (up to 1.5 Bar or 22psi boost)
 Wideband _auto tuning_ using user definable target AFR table
 USB and CAN Communication Port
Factory Outputs:
 4 x Fuel Injector outputs
 4 x Ignition outputs
 VTEC, Coolant Gauge, AC Clutch Relay, Idle Control
 Thermo Fan, Check Engine Light, Fuel Pump
Factory Inputs:
 MAP sensor, Throttle Position Sensor, Knock Detection sensor,
 Coolant Temperature sensor, Vehicle Speed Sensor,
 Air Temperature sensor, Power Steering Switch, Narrowband Oxygen sensor
Expansion I/O*:
 2 x Analogue Voltage inputs
 2 x Analogue Temperature inputs
 4 x Digital Outputs
*Optional auxiliary harness required to be purchased Haltech Part # HT040003
Functions:
 VTEC On _ INJ / IGN Tables
 VTEC On _ CAM Table
 Closed Loop O2 Control
 Decel Cut Over Boost Rev Limiter
 Closed & Open Loop Boost Control
 Gear Setup
 Transient Throttle Enhance
 Knock Control
 Long Term Fuel Trim
Correction Tables: Fuel Ignition Boost:
 Cranking
 Air Temp Target Correction
 Zero Throttle Gear Correction
 Cylinder Trim
 TPS Correction
 Generic Correction 1
 Generic Correction 2
 Gear Correction
 Post Start
 Air Temp Duty Correction
 Post Start
Miscellaneous:
 Data Logging: 448Kb of onboard data logging, Storage for approx 40 minutes at 10 logs per seconds,
6 channels of data
 Max 20 channels logging capability
 Tune can be password protected in software
 Rugged anodized aluminum casing
Power Requirements:
Source: 8.6 to 16.5 Volts DC
Consumption: 530mA @ 12Volts DC
Physical Dimensions:
ECU Dimensions Length: 154mm (176mm with MAP nipple)
Width: 158mm Height: 42mm Weight: 680g (1.5 lb)
Applications: Honda S2000 (AP1)
The Kit includes:
Pro Plug-in ECU, USB Cable, Programming Software CD, Quick Start Guide, Instruction Manual (on CD)
PM OR POST UP TO GET YOUR S2KI SPECIAL PRICING!!
Regards,
Robert
Chops@MVP is offline
Old 02-26-2012, 11:22 AM
USAF_S2K's Avatar
ill take a price, whats up with the aux cable you have to buy?
USAF_S2K is offline
Old 02-27-2012, 01:16 PM
Chops@MVP's Avatar
PM sent!
Regards,
Robert
Old 03-01-2012, 03:14 PM
Chops@MVP's Avatar
PM sent!
Regards,
Robert
Old 03-06-2012, 09:23 AM
Chops@MVP's Avatar
PM's replied!
Regards,
Robert
Old 03-12-2012, 10:03 AM
Chops@MVP's Avatar
Thanks for the orders S2KI!
Regards,
Robert
Old 03-13-2012, 05:01 AM
raz0rbladez909's Avatar
Pm pricing shipped to 92563 please and thanks
raz0rbladez909 is offline
Old 03-13-2012, 01:06 PM
Chops@MVP's Avatar
PM sent!
Regards,
Robert
Old 03-13-2012, 01:20 PM
devildust's Avatar
price shipped to 60005
devildust is offline
Old 03-16-2012, 09:39 AM
j3ff's Avatar
price shipped to 02453?
j3ff is offline
Quick Reply: Haltech Platinum PRO Plug In ECU for Honda S2000 AP1! MVP Motorsports
