Catalytic Converter - OEM vs Test Pipe vs Magnaflow
Old 03-12-2012, 04:30 PM
pawel2k's Avatar
Default Catalytic Converter - OEM vs Test Pipe vs Magnaflow
Hey Gents,
I got an 04 AP2 and my catalytic converter need replacement, so i am looking at some advice what should i get the oem replacement or test pipe or mangaflow direct fit one.
Note i currently have stock exhaust and latter i will be looking into going aftermarket.
So the big question is what does everybody run and which one ( is aftermarket which company )? Or any good suggestions?
Thanks,
Pawel
Old 03-12-2012, 04:54 PM
bigmacnfries's Avatar
Test pipe if you're only concerned about gaining power. If you care about the trees and bunny rabbits, then the HFC would be a better option, and nearly as good as a test pipe.
If you are worried about emissions testing, then the HFC is your best bet.
Old 03-13-2012, 01:37 AM
alricl's Avatar
I'd recommend the Berk HFC if your looking at a hfc option.
Old 03-13-2012, 05:52 AM
JackS's Avatar
First off, have Honda replace your defective CAT. This is one part that has a 10 year warranty. Might as well keep an OEM as a spare or for resale.
Old 03-13-2012, 07:32 AM
Gernby's Avatar
Here's a thread comparing the performance differences of a test pipe, HFC, and OEM cat. If you have the ability to tune and lower VTEC, then you'll get big gains from a TP or HFC.
https://www.s2ki.com/s2000/topic/842...-tps-and-hfcs/
Old 03-13-2012, 08:00 AM
ungucpho's Avatar
have the cat replaced, and buy a test pipe. that way you can swap back if emissions are checked
Urge
153
09-01-2018 07:35 PM
FISH22
09-01-2009 06:00 PM
Bliss@5200
12-30-2007 01:43 PM
dmpts2k
02-24-2006 10:35 AM
supman
05-05-2004 05:47 PM
Quick Reply: Catalytic Converter - OEM vs Test Pipe vs Magnaflow
