PASSENGER WINDOW WONT GO UP!
Old 04-22-2012, 11:54 PM
NAs2kCR's Avatar
Default PASSENGER WINDOW WONT GO UP!
So my car is now On the fritz! The passenger window won't roll up or down. I have replaced the driver and passenger switch 2 times per side and it's defiantly not a faulty switch.
So next thing I did was pull the door panel off and put power manually to the switch, the window went up and down. So I know the motors and switches are ok, what else could it be? I hear the relay clicking under the dash. Could it be a faulty relay? Is my wiring toast somewhere? I pulled the dash out and chased anything and everything. I'm to the point of wiring a direct harness from my switch and window to its own power source, just so I don't have to deal with this shit anymore.
Any help would make my life a lot easier.
Old 04-23-2012, 12:02 AM
ghettocrxsi's Avatar
Dumb question but do you have the window lock on?
Ndnola (10-13-2022)
Old 04-23-2012, 12:05 AM
NAs2kCR's Avatar
And I checked fuses
Old 04-23-2012, 12:06 AM
NAs2kCR's Avatar
Window lock is off, I'm slow, but not that slow.
Old 04-23-2012, 09:45 PM
9MMSWORD's Avatar
check the under dash fuse box fuses 8, 17 and 18 also in the harness side of the master switch check the blu/wht and blu/red wires for contact and that they are in the plug correctly, check the plug to the passenger window switch for the same thing, also check under the left kick panel the c502 plugin( plug closest to the silver metal box) that has all the passenger and convertible wires through it.
Old 04-25-2012, 11:10 AM
NAs2kCR's Avatar
Checked all of it. It's all solid. Anyone have a wiring diagram I can use so I can just re wire it?
Old 04-25-2012, 01:02 PM
Banned
HondaRehab's Avatar
Good luck man.
I can't really offer any advice but electrical problems are my least favorite thing to trouble shoot.
Old 04-25-2012, 09:29 PM
9MMSWORD's Avatar
don't rewire it, theres a fault somewhere you just need to find it. Ill try to get diagrams for you and diag instructions
Old 04-25-2012, 09:52 PM
9MMSWORD's Avatar
here
1. remove the master switch but leave it plugged in
you'll need a multi meter and a simple ground wire.
complete this, and let me know.
Old 04-26-2012, 12:03 AM
NAs2kCR's Avatar
^^ you rock! I was trying to find this. Was about to just download the Manuel for 20$. I appreciate the help. I'll keep you posted.
Quick Reply: PASSENGER WINDOW WONT GO UP!
