1999 engine change
Old 05-24-2012, 06:53 AM
crashnberg's Avatar
Default 1999 engine change
Hi Guys an Gals, I have a 1999 silverstone with a knocky engine. I want to replace the engine to allow me to rebuild the damaged one without time pressure, but need to know which engine i can put in it. I have found a 2005 unit but am unsure if i can just fit it or if other parts need to come across from the donor car. Could anyone give a description of engine years/codes that could go in and what would need to come with them. This will help hugely in choosing the replacement. Sorry this is my first post - I have only had the car three days!!
Kind regards
Jared
Old 05-24-2012, 01:54 PM
crashnberg's Avatar
Kind regards
Jared
Someone must know?
Old 05-24-2012, 02:49 PM
g352s2k's Avatar
I would just stick with an ap1 motor since you are building your old one. 03 & down.
Old 05-24-2012, 07:39 PM
Billman250's Avatar
Received 1,253 Likes on 763 Posts
a 2004-2005 2.2L engine will drop right in.
Only caution is taking it to 9k. You may want to limint your shifts to 8500.
There are those who successfully run the 2.2 to 9k with the 00-01 ecu also.
Old 05-24-2012, 11:47 PM
crashnberg's Avatar
I forgot to say I'm in the uk. So what is the difference in these engines? Thanks for the reply.
Jared
Old 05-24-2012, 11:50 PM
crashnberg's Avatar
Thanks for the reply. So for the uk the 2005 motor is different but can work with my inlet/exhaust manifold etc?
Jared
Old 05-24-2012, 11:51 PM
crashnberg's Avatar
Thanks for the reply! So what are the differences in the engines - I forgot to say i'm in the uk. Neither is a 2.2 as far as i know.
Thanks again
Jared
Old 05-25-2012, 06:19 AM
Stratocaster's Avatar
Since you are in the UK, the 2005 motor will drop right in. It is a 2.0 so you have not ECU things to worry about. You might want to pick up the transmission too if you can. they changed the internals and updated the syncros and that alone may be worth what they are selling it for.
Old 05-26-2012, 04:28 AM
AP1Theory's Avatar
Everything should bolt right up with the '05. It's the '06 and newer engines that would be a little different, but even the '06+ engines would work after you've swap a couple of parts from your old engine. Everything still bolts right into place.
Mr.Matchbox
06-22-2018 07:54 PM
ap2ner daygo
San Diego S2000 Owners
06-07-2011 06:40 AM
pinoyk20
11-23-2007 08:35 PM
heart
11-23-2007 01:37 PM
Quick Reply: 1999 engine change
