Passenger window won't go down
Old 05-25-2012, 11:22 PM
N5THM's Avatar
Default Passenger window won't go down
Ok this has been bugging me for months now and I really need to get it sorted.
No matter what button I use, passenger side, driver side or roof button it doesn't work, so I investigated further.
I bought a 2nd hand window regulator, and as soon as I plug the passenger switch into the socket the window motor goes up, it seems to be getting constant power, i think this is why the old regulator does not work i think the constant power has burnt the motor out, if I unplug the passenger switch from the regulator I can send the motor down with the drivers side switch but not up? above the passenger footwell in the dash there is a clicking noise so I am guessing there is some sort of relay unit in there?
I dropped it onto my local mechanic and he had a look around and couldn't figure out any more than what I can apart from there needs to be some master control box somewhere that could be screwed?? Local Honda want £80+VAT per hour to even start to look at it.
Inside the doors there is some dynamat so someone has been into the doors before, Anyone get any ideas on what I can even look at? Or does anyone know where I might find some wiring diagrams?
any help appreciated
....oh an its not the driver lock off button before anyone asks
Old 05-25-2012, 11:51 PM
Nottm_S2's Avatar
You could look here
http://www.hondaoriginalparts.com/ho...p?mod_01=19247
Not aware of any wiring diagrams though, sorry
Old 05-26-2012, 12:03 AM
N5THM's Avatar
Thanks ill have a look,
Been reading up a bit more and other people that have had a similar issue say its linked to the soft top module, my soft top still works all ok, and the module is actually where i said the clicking noise was coming from?
Old 05-26-2012, 12:35 AM
Nottm_S2's Avatar
there's one on US fleabay http://www.ebay.co.uk/itm/2005-HONDA...ht_1818wt_1037
otherwise i guess a uk breaker would sell you one for not much money? loftus might have one or the other guys who broke cars. worth a try at that money?
Old 05-26-2012, 01:01 AM
Banned
mattg4321's Avatar
Just found this for you in my service manual.
NOTE: The drivers switch is combined with the control unit so you cannot isolate the switch to test it. Instead, run the master switch input test procedures (see step 5 on page 22-126)
Also has a wiring diagram on page 22-123 and a step by step procedure to find the problem.
A quick search on google/filestube etc for s2000 service manual should find you a pdf copy.
Old 05-26-2012, 05:19 AM
Floppy's Avatar
I have a soft top module available. PM me if you're interested.
Old 09-23-2013, 10:05 AM
pdtrewern's Avatar
Hi,
What was the outcome?
I now have the same problem..
Ta.
Old 09-23-2013, 11:06 AM
GaryB's Avatar
When did your passenger window last work?
Does it go down when you drop the roof?
Old 09-23-2013, 12:56 PM
MSC
MSC's Avatar
Originally Posted by pdtrewern
Hi,
Ta.
Is the passenger window 'lock' on?
Old 09-24-2013, 12:06 PM
pdtrewern's Avatar
Worked fine until...
Changed front speakers, but I don't think it is related...
Drivers window ok. Both passenger switches click relay to try and go down (but its already stuck down of course) but both do nothing to get passenger window up. Volts at motor read ok down, but do not reverse so would suggest other problem.. Roof operates ok..
I read somewhere perhaps roof module?? Confused..
Quick Reply: Passenger window won't go down
