Ultra-gauge
Ultra-gauge
I needed a voltmeter after my battery discharged so I got an Ultra-gauge
http://www.ultra-gauge.com/ultragauge/index.htm
It attaches to the OBDII port and reads info off the ECU
This thing is small about the size of a credit card and it also clear CEL codes
It is also easy to mount anywhere and I mounted it on the hardtop latch
I haven't tested it much but so far I like it, the refresh rate is pretty quick
Not bad for $80 bucks
i got one too! but it's the old version. great price for an obd2 reader. i mounted mine next to the steering column and used double sided tape. how did you run the cable to the obd port?
It depends, you have to check for your year
http://www.ultra-gauge.com/ultragaug...augelookup.php
But it has over 50 different parameters for '06 and up
I mounted mine in my radio door. It's been there now for a a few months. Don't have a pic right now, but maybe I can snap one later.
Pros:
- Extremely readable, even with the top down and direct sunlight
- Easy to use
- Multiple "pages" or screens with custom displays
- Alarm/Warning feature (e.g. beep at above X engine temp)
- Price
- Acts as real-time gauge and code reader.
Cons:
- Limited usefulness as real-time gauge. I'm only using it to monitor Engine Temp and Intake Air Temp.
- Bastards never sent me my rebate or responded to emails. (Looks like they're not doing a rebate right now).
Pros:
- Easy to use
- Price
Cons:
I still have mine but never installed it in the s2000. I originally ordered it for my '10 mazdaspeed3 because they don't have anything to monitor coolant temp and after adding an intake to it I added fuel trims to the main page too. What do you guys have set up to monitor on it?
