Rear Wheels "Wobble"
Hello S2Ki,
I was notified by a passerby that my rear wheels "wobble and bounce". Since I got my tires mounted onto the wheels from a powdercoat shop, I was assuming that the tires weren't balanced because the shop guys mentioned they had a difficult time mounting them onto the wheels. But after researching (and by "research" i mean google) further I read it can also be a bent axle, bent rim, conflicting wheel sizes, etc. I just wanted to know if anyone has experience this problem before and any insight would be appreciated.
Here are my wheel/tire sizes:
17x8 +38
245/40/17
Also, lowered on KGMM Springs for a ± 1.5"
17x8 +38
245/40/17
Usually when it looks like a tire wobbles or bounces it's just different shades of color playing tricks on your eyes. I see it all the time on truck tires that have a spot of mud on the sidewall. Can you better describe what they actually told you? The other symptom could be a blown shock absorber, in which case the wheel will bounce and you'll see tire tread damage (cupping).
An out of balance tire will be felt when driving, but I can't be so sure as to say that you'd see anything with your eyes on a passing car.
That's my .02.
-Mike
That's my .02.
-Mike
That's my .02.
-Mike
That's my .02.
-Mike
Thanks for your input. I'm familiar with the spots of mud on the sidewall, but this was after a wash and it's been dry for weeks. Unfortunatly, that's all the passerby said and I was planning to get a mechanic buddy of mine to trail me as I drive. But now that I'm aware that my tires wobbling, I now notice it. Not sure if it's just a placebo affect since I was told, but I may have disregarded it because with these springs you feel every tiny bump in the road.
Site Moderator
Or let someone drive it and not mention it and see if they feel it. Like others have said you should feel it at least at certain speeds. I would take the car to a tire shop and have them balance them. If that doesn't fix it then look for bigger things. Also sounds dumb but just take the wheel off and put it back on and re torque the lugs. If they are alittle loose it could make it wobble some.
lol!
Thanks for all the suggestions!
CKit, no grinding noises from the bearings, but I'll check out the lug nut torque and axle nuts when I get a chance. Thanks!
