Subaru BRZ STI Concept
Didn't see a thread about it. Thing looks mean. First thing I would do is get rid of that wing though, looks cleaner without it.
[From Subaru Press Release]
Styling
• By installing the Boxer engine as low as possible, the low hood and sleek roofline together compose a sophisticated form. This is also blended with STI performance touches for a Subaru sporting profile.
• A hexagonal lower front grille, hawk eye headlights and fin-shaped fog lamps make the front face instantly recognizable as Subaru.
• STI-made lower front spoiler and rear wing magnify down-force and aerodynamics performance. They allow stable straight driving and excellent handling at high speeds.
• The rear design with bold rear fender flares, large rear-diffuser, and twin dual tailpipes intensifies the STI performance feel.
• A carbon-fiber roof, already installed in a WRX STI model and highly acclaimed, has been employed by the concept car. With it, extra weight reduction and an even lower center of gravity were achieved, contributing considerably to the ultimate handling performance this concept model aims to offer.
• The lively exterior color “WR Blue Pearl II” is a new generation of the iconic WR blue paint scheme that emphasizes the racing image.
Engine
• The Boxer engine has inherent qualities of light weight, compactness, low center of gravity, and high rigidity – all pointing toward its great potential as a sports car engine. Taking full advantage of these features, a 2.0-liter horizontally-opposed four-cylinder direct fuel-injection gasoline engine has been developed exclusively for BRZ.
• The engine has been designed with a square bore and stroke of 86 X 86 mm. Combined with Toyota’s D-4S direct injection technology (fuel injection system), high output and high environmental standards were both attained, both expected of a new generation sports car.
Chassis and Body
• Compared with other Subaru models, the engine in SUBARU BRZ CONCEPT - STI - sits an impressive 120 mm lower and is positioned 240 mm closer to the center of the chassis. As a result, this car has achieved one of the lowest possible center of gravity in cars on the market today.
• By incorporating lightweight parts such as a carbon-fiber roof, the overall weight has been reduced. Subaru has also succeeded in attaining a body structure that is both lightweight and highly rigid in a striking balance. The concept car is the embodiment of pure driving enjoyment only obtainable with a “Boxer sports car”.
• Its unique handling performance has been remarkably refined by adopting STI’s lightweight 18-inch alloy wheels with performance tires and STI tuned suspension with excellent lateral stiffness.
• Brembo brakes enhance braking performance.
Major Specifications
Overall Length × Width × Height (mm): 4,230 × 1,800 × 1,280
Wheelbase (mm): 2,570
Engine Type: 2.0-liter direct fuel injection naturally-aspirated 4-cylinder
Horizontally-Opposed Boxer engine
Tires: 215/45R18 (Front), 225/45R18 (Rear)
Styling
Engine
Chassis and Body
If they ever build a car close to that, with more power than the standard BRZ I will certainly be looking at it!
That's more like it...
saw this at the LA auto show last year. It looks a lot better than the base BRZ, I thought they were going to bump the hp to around 260-270 range via FI though? This article states it will be the same NA motor.
Maybe was an older article, here's a fresher one.
http://www.topspeed.com/cars/subaru/...-ar127134.html
Ever since Subaru dropped the new BRZ onto the market, we knew that an even hotter STI version was sure to follow. Now, British magazine AutoExpress is offering a few details on this new model, set to arrive sometime next year.
The future BRZ STI will feature a more powerful version of the current 2.0-liter flat-four cylinder ’boxer’ engine. The output will be raised up to somewhere in the 250 HP area (an addition of about 50 HP) thanks to the modifications made to the engine’s variable valve control system. That will also allow for an even higher rev limit of around 7,500rpm with the help of a new freer-flowing exhaust.
Next to the extra power, the new STI will also be even lighter than the standard BRZ. It will also be distinguished by a dramatic bodykit, a stiffened and lowered suspension, lighter but larger 18-inch alloy wheels, and upgraded brakes.
One downside to the BRZ STI is that there will be no turbocharged version offered. Subaru says there is no space for it in the engine bay and they are reserving these version for models like the WRX STI.
