Skunk2 Stage2 cams, comparaison dynosheet included
Hi guys, I always heard a lot of bad things about Skunk2 cams In F2Xc engine, but never really seen a setup how really have the supporting mod to use those.
Since I have a Dynojet Dynamometer, I decide to install those on my f22c for testing
we compare here
f22c 2004 80000 km
stock TB
stock AP2 cams
stock intake tube
PasswordJDM snorkel with BPI 3'' velocity stack and K&N 6'' Air filter
S2000 megapower rare header
Invidia 70 mm test pipe
Challenge USA GTA-S exhaust (75mm)
Hondata Kpro fully tuned
VS
f22c 2004 80000 km
Skunk2 Pro Serie 74 mm TB with intake port matched
Skunk2 Stage 2 cams
3.5'' intake tube
PasswordJDM snorkel with BPI 3.5'' velocity stack and K&N 6'' Air filter
before changing the cams, the car was test with the 3.5 intake, and only give 2 whp on dynoruns with complete tuning.
here is the dynograph before and after
never forget that all skunk2 Cams for S2k required head porting to deliver the full potential
I also test with custom tuned 3.5'' CAi that a made and peak the power at 234 whp
we compare here
f22c 2004 80000 km
stock TB
stock AP2 cams
stock intake tube
VS
f22c 2004 80000 km
Skunk2 Stage 2 cams
3.5'' intake tube
nice gains! so when you added the cams, you also changed the throttle body and replaced the stock intake tube with one of the same exact shape but with a 3.5 inch diameter correct?
me personally, i would get rid of the snorkel and just make one long pipe. i'm sure there's more in it.
do you plan on adding cam gears and degreeing the cams?
The test before and after was both done with 3.5 tube to and the stock air tube, the power with stock cams was 218-220whp (with stock tube or 3.5 tube)
With the cams and the 74 mm TB it's 232 with 3.5 short tube and snorkel, and 234 with 3.5" CAI
I'm not sure what I will do next, I want to test Brian Crower 2 and 3, and I don't knoe if I want to pay for the expensive toda cam gears.
I take a look to test Inline Pro Intake manifold, or a custom made by Raceheads
Originally Posted by Croc' timestamp='1347610040' post='22010905
so 14 HP.
it would be interesting to know how much of this power was dut to TB and how much due to cams....
Supradriver08
02-02-2012 11:04 PM
06Estukay
07-20-2011 09:58 PM
