2000 cc with single 340 lph
Old 09-16-2012, 03:01 AM
alanpikku's Avatar
Default 2000 cc with single 340 lph
Anyone running this setup? I'm trying to aim for around 600 whp, currently making 500 whp using a single 340 and 1000 cc injectors. I'm upgrading my injectors, so not sure if I have to run a duel Walboro setup. I want to keep my fuel pressure stock like it is now.
Old 09-16-2012, 03:38 AM
anarchy187's Avatar
What type of fuel?
Old 09-16-2012, 04:44 AM
camuman's Avatar
Looks like e85. Should be doable.
Old 09-16-2012, 12:52 PM
passmans2kny's Avatar
my buddy made 613/407 @ 21 psi, that was with dual 340s, but his injectors were maxed out there anyway, at 75 base pressure
Old 09-16-2012, 12:56 PM
alanpikku's Avatar
On E85.
Old 09-16-2012, 01:09 PM
Irishflame27's Avatar
Originally Posted by alanpikku
On E85.
per Jeff Evans, if you bump your fuel pressure up to around 75psi base, you will make the 1000's into 1300's. Should be able to max out a 340lph and your injectors at ~600whp
Old 09-16-2012, 01:17 PM
miguel329's Avatar
Originally Posted by Irishflame27
Originally Posted by alanpikku' timestamp='1347828960' post='22015767
On E85.
Hmm planned on ordering id2000 but i want stop 600whp so may just keep id1000 then
Sent from my PC36100 using Tapatalk 2
Old 09-16-2012, 02:18 PM
alanpikku's Avatar
On E85.
Thanks for the info, but I went ahead and ordered the ID 2000 injectors just for room to grow. It sounds like I should be able to hit 600 whp with the 340. Don't plan on pushing anymore until I upgrade the diff.
Old 09-16-2012, 07:27 PM
vduber's Avatar
I want to see how this pans out
Old 09-16-2012, 07:32 PM
alanpikku's Avatar
I will keep you guys updated with a new thread. Everything should be gtg in 2 weeks.
Quick Reply: 2000 cc with single 340 lph
