Mark this thread as Unsold
FS: loads of supercharged race stuff AEM FBM Berk dms winter tyres
Most prices negotiable, this stuff has to go!!
DMS 76s - single exit 76mm exhaust £450
ID1000 injectors x 4£350 may become available depending on above
AEM digital temperature gauge. £110
AEM 5gallon water methanol injection kit. Installed and removed! £210 rrp over $570. Comes complete with MAP based flow controller, two nozzles and a number of different jets and new filters.
http://www.aemelectr...ternal-map-1308
AEM water methanol failsafe controller £150 rrp $280 like new.
http://www.aemelectr...ce-1-4-sae-1184
Big throttle body ld 74mm with port matched, gas flowed and polished oem inlet manifold .£500 reduced now £380 - available 1month
Full Blown Motorsport 74mm billet aluminium throttle body. OEM inlet manifold all ported to match the TB and cylinder head. it was done by an engineering company where it was also deburred and polished inside. I wouldnt imagine this would help on an NA car but it should really free up some ponies on an FI car. Unfortunately I have no comparison Dynos but my tuner says this really helps. Only reason im is because im going even bigger again
Oem hardtop fitting side catches £350
J's Racing Silencer Bung new £50
16"Goodyear winter tyres. £120
DMS 76s single exit 76mm stainless steel exhaust. Reduced £425, used for less than 1000dry miles.
FLOOR MATS 4 piece black honda floor matts, 2 years old but like brand new. Sat in the garage most its life. £155
a pair of rear oem ten spokes. Oem 17" v3 £300
Space saver wheel and tyre £10
Oem tape player with code £30
Airbags- £60 each
Pretensioner / Seat belts including reels- £50 each
SRS module (the one behind the radio) - £50
1999 Steering wheel - £50
Rear panels for rear speaker instal - £50
Exhaust manifold £40 perfect condition
Inlet manifold £80
Throttle body £30- several 1999my available !
Yellow bonnet good paint - £150
Yellow boot with oem low spoiler - £200
Oem uk rear bumper needs paint £30
Water radiator £40
Aircon rad £30
Aircon compressor £50
Aircon condenser £20
OEM struts/coilovers complete - £30 each
Airbags- £60 each
Inlet manifold £80
Water radiator £40
Aircon rad £30
