Συμπεριφορά Συζητηση σχετικα με τη συμπεριφορα του αυτοκινητου, οπως ευθυγραμμιση, αναρτησεις, φρενα, ελαστικα ζαντες και βελτιωσεις
ζαντες 17
Old Mar 21, 2012 | 01:48 PM
sakis2000's Avatar
Default ζαντες 17
παιδια γεια σας.ειμαι νεος στο forum αλλα λιγο παλιος στα honda.ψαχνω για ζαντες στο s 2000 και εχω μπερδευτει πολυ.καρε offset κτλ ειναι τρελος πονοκεφαλος.θελω 17 αρες για να δειξει λιγακι το αμαξι και ψαχνω οζ και work.δεν προκειτε να βαλω replica σε τετοιο αυτοκινητο αλλα ουτε και την μαμα 17αρα.αν μπορειτε...βοηθηστε....εδω στην επαρχια τα συνεργεια ειναι πισω απο τον κοσμο..
Old Mar 21, 2012 | 01:54 PM
uma_chikara's Avatar
Ορίστε, φίλε μου..
Based on successes and failures from many S2000 owners, we can use an offset calculator to figure out what other offsets and tires will work. These are minimum recommended offsets. You can use a higher offset if you want, and you will get additional fender clearance.
For the front:
Offsets lower than +43 are not recommended on the front because a very narrow tire would need to be used to avoid rubbing.
+43 to +47 offset: 205 tires, 6.5" - 7.5" wide wheel
+48 to +52 offset: 215 tires, 7.0" - 8.0" wide wheel
+53 to +57 offset: 225 tires, 7.0" - 8.0" wide wheel
+58 to +62 offset: 235 tires, 7.5" - 8.5" wide wheel
+63 or higher offset: 245 tires, 7.5" - 8.5" wide wheel
For the rear:
Offsets below 40 are not recommended for the rear because a tire narrower than the stock tire would need to be used to avoid rubbing.
+40 to +44 offset: 235 tires, 7.5" - 8.5" wide wheel
+45 to +49 offset: 245 tires, 7.5" - 9.0" wide wheel
+50 to +54 offset: 255 tires, 8.0" - 9.5" wide wheel
+55 to +59 offset: 265 tires, 8.5" - 9.5" wide wheel
+60 to +64 offset: 275 tires, 9.0" - 10.0" wide wheel
+65 or higher offset: 285 tires, 9.0" - 10.0" wide wheel
Note: Verify wheel width by checking the tire manufacturer's specifications . These are guidelines that should work for most wheel and tire combinations.
The offsets above will all set the outside edge of the tire to the same place relative to the outer fender, rounding to the nearest millimeter.
4.1 OEM Fitments
For reference, the OEM MY00-03 (AP1) wheel sizes and offsets are as follows:
Front:
16" x 6.5", +55 offset, 205 tire
Rear:
16" x 7.5", +65 offset, 225 tire
and the OEM MY04+ (AP2) wheels are as follows:
Front:
17" x 7.0", +55 offset, 215 tire
Rear:
17" x 8.5", +65 offset, 245 tire (255 on the S2000 CR)
Καρέ έχουμε 5x114.3 όπως τα περισσότερα σβέλτα γιαπωνέζικα όπως Evo, Impreza, 350z κ.ο.κ
Old Mar 22, 2012 | 05:12 AM
sakis2000's Avatar
Σ ευχαριστω πολυ φιλε μου.χρησιμες οι πληροφοριες σου.με ενδιαφερει επισης αν υπαρχει και καμια μεταχειρισμενη ζαντα οz η work να αγορασω.μηπως γλυτωσω κανα ευρω τωρα με την κριση.ευχαριστω και παλι
Old May 14, 2012 | 05:26 AM
S2000_FUN's Avatar
Originally Posted by kickerakoc
exw 18 ch r ama thes egw
Θα σε παρακαλέσω φίλε μου να γράφεις Ελληνικά μιας και τα Greeklish απαγορεύονται στο φόρουμ. Και άμα μπορείς πέρνα από τα νέα μέλη να μας πει κάτι για τον εαυτό σου
TP1
Jul 11, 2009 10:50 AM
TryPsi41
Aug 29, 2007 02:55 PM
no_s2k
Jul 16, 2007 09:40 PM
s2kkk
Jan 22, 2006 01:53 PM
johns2000
Feb 5, 2005 08:51 AM
