Mark this thread as Sold
Cave Creek: turbo kit part out
Joshua
$2000 picked up $2200 shipped CONUS for everything listed
Cave Creek, AZ
Contact me by pm or by replying to this thread. Pm is quickest way to contact me.
Willing to part out kit! Let me know what you want.
Selling a custom turbo kit based on Inline Pro's Stage 1. This does not come with a turbo. I made 351 whp on 12 psi with a Turbonetics TN 500hifi.
Turbo kit includes:
$360 shipped~Inline Pro Stage 1 cast t3 manifold that has been Extrude Honed and coated with Swaintech White Lightening. Extrude Honing removed all the rough cast marks within the manifold, so the surface is smooth and almost polished (now covered in carbon buildup). Swaintech White Lightening is one of the best ceramic coatings available. The finish is starting to flake off after a few years of use. Will include ARP extended exhaust manifold studs (no nuts).
$400 shipped~Inline Pro 3" downpipe with a 4 bolt flange and a recirculating wastegate tube. Comes with an Asura 3" resonated testpipe. This will bolt up to any standard cat back exhaust.
$120 shipped~Tial MVS 38mm wastegate. Black in color; turned a variation of black cherry like all black anodized metal does when subjected to heat.
$300 shipped~Revhard intercooler piping and intercooler. This piping routes under the front cross beam, so it is not compatible with front bumpsteer kit. I believe it is 2.25" hot side and 2.75" cold side. Assorted t-bolt clamps and couplers for intercooler piping.
$140 shipped~Tial BOV. This is the previous generation and is also black in color.
$220 shipped~Ultimate Racing oil filter relocation kit with extra o-rings and crush washer. Includes -8 Earl's Prolight 350 lines and a combination of Earl's and Russell AN fittings. The lines are not constructed to proper length, so they will need to be cut and reassembled. Come with turbo oil feed line as well.
$50 shipped~3" metal intake with AEM Dryflow filter and new Vibrant 3" coupler.
$50 shipped~Hondata 4 bar Map Sensor.
$offer~GM boost solenoid (boost controller)
$675 shipped~AEM 1052-0230 ECU with Modifry ECT for ap1 and Alloy Craft AEM ECU bracket. Still has the tune (2.0L)for 12psi with the RC 750, Hondata 4 bar Map sensor and GM boost solenoid.
$offer~NGK Iridium IX spark plugs BKR8EIX. These have less than 5k miles.
$120 shipped~tapped oil pan and oil drain line. Threads are perfect. Has some jb weld around the welded bung because it looked questionable. I really don't think it was needed. Has never leaked.
Off the top of my head, this is what is needed for this kit to be complete: turbo, oil line fitting/oil restrictor for turbo, vacuum lines, oil lines for oil filter relocator (-8AN), bolts for turbo to manifold and downpipe to turbo and injectors.
Things I will accept to lower the price of the turbo kit:
~Ballade Sports header or Urge Unicorn header
~Greddy E-Manage Ultimate w/PNP harness
~Harddog double Diagonal roll bar or Rockstar double diagonal roll bar
~AP1 diff with 4.44 gears
~APR GTC-200 or CR wing
~Good condition Berlina black trunk
~Recaro Pole Position (1 or 2, prefer black)
~(2) SSR Type C RS 17x8.5 (+49 or +58)
Cave Creek, AZ
Turbo kit includes:
