Tires question
I'm running Bridgestone Potenza RE050 on my 2006 S2000. The tires have 8250 miles on them and I am already getting very close to the wear bars on the rear tires. 7/64 of an inch to be precise on the outer tread of each rear tire. The fronts are deeper. I am the 3rd owner of the car, owning it for 4 1/2 years and having driven it for just a hair over 14000 miles. I replaced the tires when the car had 21900 miles on it. I am religious about checking the tire pressure and running them at 32psi. The car is not a daily driver, is NOT tracked and it is used specifically for the roads in NW Arkansas. That means chip seal and warm to hot weather, 6 BMTs since the tire change and lots of driving that would be considered aggressive by some normal drivers but much below the style of driving in a BMT Group 1 - the slow group - environment.
Is this normal wear for this brand and model of tire or is it excessive given the above usage style. The tires are the OEM tires that came new with the car. They are not cheap tires if you price them out at tirerack.com. I don't think I'm doing anything ill-advised, and as I said I always check the pressure before driving it. I really like the tires, they hold very well and ride nicely. Given the amount of driving I do with this car, they've gone 3 years, but the mileage certainly is disappointing. What do others in the NWA/NE OK/ S. MO area find in terms of mileage given the above conditions? What tires are you running to get the mileage you are getting. I've had fun with the tires, and if they are known for getting less than 10000 miles than so be it. I just want to make sure it's nothing I'm doing to mess with the mileage. I've certainly had fun in the miles I've put on the car and tires!
Thanks for any info you can share.
Scott
Scott
I'll have to look at my records and do some math so will get back to you on those details but I just wanted to mention that outer wear is not as common as inner wear. Might want to have the alignment checked.
Scott
Scott, After going through several sets of Bridgestone RE050 PP tires, I switched to Bridgestone S-04 tires which have the same dry & wet excellent grip and come with 1/32" more tread depth. Since my '02 S2000 is supercharged (310 rwhp), the rear tires wear out twice as fast as the front tires (I never do burnouts or speed shifting!). After supercharging the car, I bought a set of 17" AP2 rims and went with 225-width in front and 255 in the rear: these wider tires cured the over-steer problem my '02 AP1 had with the 16" OEM 205 & 225 width RE050 tires. When driving a BMT, I run 33 psi front and 32 psi rear (cold) pressures. Since only about 60% of my driving in the S2000 is "normal" driving," my tire wear mileage is near your wear rate for the front tires. The Bridgestone 050 & S-04 tires are "old" rubber compounds now and there are much better new rubber compounds available on the market, I too am considering changing tire brands for the next set for my S2000.
Like Jerome, I too run Bridgestone S-04s and got about 11,000 miles out of the last set of rears but only 8,000 miles out of the rear set before that which I suspect is because of the alignment at the time which has since been adjusted to my driving style.
If you're interested in trying out some custom alignment settings, here's what I run. It's a little less aggressive than UK spec, or you might even want to give UK spec a try.
UK spec is great for the twisties. I ran it for a while, but after experiencing excessive inner tire wear due to driving on mostly interstate highways for 800+ miles to get to the Dragon and another 800+ to get back, I toned it down a bit. I still wanted it to handle like it did (or close to it). If I lived closer to the twisties, I'd probably still run it, but for me, getting to the fun roads requires driving at least an hour on straight boring roads so, with some help, I came up with this slightly less-aggressive-than-UK-spec alignment:
Max out caster (6.2-6.7)
-1.0 front camber
0.04 front toe (each side)
-2.0 rear camber
0.12 rear toe (each side, so 0.24 total)
I've found that this is a good compromise for excellent handling without the excessive uneven tire wear. This might not be for everyone but it's worked for me. A friend of mine managed to put an insane amount of miles on a set of RE-11s with UK spec and they wore evenly but he rotated them frequently.
-1.0 front camber
-2.0 rear camber
