Dc5 Brembo on s2k
Dc5 Brembo on s2k
Hi guys, planning to put the dc5 brembo front calipers on s2000, I know they fits with 7.5mm spacers. What I am trying to do is instead of putting a spacer, i would will the calipers 7.5mm to make them fit.
After I mill the 7.5mm on the bolting area, the metal will be thinner than original and would be around 10mm thickness left. I am just concerned that if it's save to do the conversion like that way...
I looked into this conversions and was put off by all the spacers (hub and wheel) and the increase in track.
I would suggest that if the initial thickness is 17.5mm and you have to mill off 7.5mm (leaving 10mm) you might be cutting it a bit thin (literally).
willed the calipers by 7.5mm this weekend, here is a photo. It actually hasn't been willed too much, recon more than 2/3 left from original
Haven't measured the thickness properly yet, but I think they will hold firmly. Yeah, will recondition and respray the calipers in a couple of weeks, can't wait to bolt them on straight away!
Milled on a milling machine. Where did you get willed?
Important not to use a cutter with a hard corner as this is where cracks will propagate from. Use a ball end cutter to put a radius where the milled section meets up with the main body.
Hi Chris, my mate machine milled for me, that's how it looks like, has he done a proper job?
Just got it repainted, they look so fresh, can't wait to put them on the car, might need a 5mm spacer to clear my wheels enkei rpf1 17x8+45, since the brembo is thicker than spoon.
Im just wondering as to why you didn't leave the caliper alone and just find a rotor with a shorter top hat.
S2000 top hats are 40mm so could of looked for another rotor from another car or make a custom 2 piece rotor that carriers the same specs.
300mm x25mm with a top hat of 32.5mm thus not needing a spacer behind rotor OR having to cut into the caliper?
none the less it will look awesome mate!
1, use s2000 rotors but need a 7.5mm spacer behind the rotors, since the rotor wont be in the center of the caliper, need the spacer to push the rotor outward.
2, use dc5 rotors but have to machine center bore to fit.
To be honest, it is very hard to find the rotor with the correct hats, size, and center bore for what I want, at least no one on s2ki has a replacement rotor to fit the Brembo, maybe this kind of rotor does not even exist.
I know a few people in the state they did that way for the conversion. the major reason I milled the calipers is, it's really easy to find replacement rotor and brake pads. And I still have enough space to put spacers for my wheels to clear the calipers.
When you say DC5 do you meen the AUDM or JDM?
Audm - 300mmx25mm with 47.5mm height
Jdm - 300x25mm with 57.8 height.
S2000 - 300x25mm with 40mm height.
I always thought if you were just to get a rotor with a 32.5mm height you would be fine or do I have it the wrong way around and its ment to be 47.5mm thus usin the AUDM rotor with machined out centre bore ??
If you use the AUDM rotor then you would need extended wheel studs correct? But if you went backwards down to a 32.5mm height rotor it would also bring the rotor in line with caliper and not needing extended wheel studs.....so I'm thinking anyway could be wrong.
