Gear box / Tranny oil..
Hey all
I know theres a whole thread on this topic.. But i wanted to know what i should be using based on Australian conditions (if that makes any difference).
Thanks
Thanks
I changed out all my lubes to Redline a short time ago.
Is it any better? Can't really say, there are heaps of threads about it.
They are top quality products without a doubt, but worth the extra$?
If you check out their website you can punch in any car and it gives you recomendations on correct product etc.
Cheers
Cheers
hey db ....
you talking about what brand/type of oil im using in my gearbox ?
if so , on my last service i got it topped up with Mobil 1 , and she does feel smoother
I switched to redline last service, and the shift action is definitely better when stone cold. When warm, well I've never had problems anyway so it's pretty much the same.
Not sure which grade my mechanic used.
Vuey, if you 'topped up' on 'Mobil 1' you're probably not doing anything and if you are it's probably bad. You don't 'top up' the oil you drain and replace. And you must use an oil specifically for the tranny. A 75w90 IIRC. I believe there is a Mobil product and it may even be titled Mobil 1, but that is a range, not an oil.
i meant the mechanic replaced it with a mobil grade tranny oil . Not sure what the actual grade was , but it was a mobil .
