my car DRINKS oil. This can't be normal. 00 model.
quarters refers to quarter of a 5l bottle right? I'm just guessing lol. I ain't having to fill THAT much.
Some people shouldn't own a car you mean!
Yes, I just read up on what a quart was hahahaha.
I'm only topping up about 0.5L every 1000 k's, depending on how much I hit VTEC, so it's not as bad as yours was steve
I'm gonna install a catch can hopefully this week, maybe that'll help?
I meant 3 quarters on the dip stick, sorry. I'm not sure what the exactly measurements are.
What I mean is, I would top up so that it would read on the H, go and drive for 500km's and then it would be around a quarter of the way between the L and the H.
I was also blowing smoke in VTEC.
New engine doesn't burn any oil at all or blow any smoke.
Can I get it tested somehow to confirm? Compression test? I don't know abuot blowing smoke.. haven't noticed anything...
I'll change oil first and see what happens. I have a 120k service coming up in 2.5k.. I'll change it then i suppose.
I really hope you don't have the same misfortune. I would get it checked out. Maybe you will have to replace pistons at worst, or it could be something else entirely.
Quarter of the way from the top (H) or bottom (L). There's a bit of difference.
Look, the H mark is full, the L mark is 1 litre down (could have sworn I already mentioned that). Every X represents 250mls.
Steve's problem would have been diagnosable by a compression test.
Originally Posted by jowjeh' timestamp='1318814370' post='21075419
[quote name='steve695' timestamp='1318813534' post='21075391']
[/quote]
I'm going to try a couple of more things before I do a compression test. I need to make sure I'm not just crazy!
Aus, you did mention the 1L between H and L. Got that part after I posted (went back and read). Thanks for that, it will help me confirm exactly how much I'm using. I'm gonna trial it again with this oil till the next service. Then I will try after the service with 10w40 and see if there's a difference.
Thanks
^ might be worth flushing the old oil out while servicing it and start afresh with the thicker oil. I switched brands and didn't flush it, so was still burning oil. Now i am almost up to 5k km, and guesstimate is I haven't top up more than 2l. If it helps, I measure how much oil I top up from my 4l tin so I know how much is being burnt off. I am using 5W40.
I changed the oil filter, drained the oil and refilled with the amsoil 10w30. That what you mean? Or an extra step (Sorry, I'm only 21, not a mechanic, I work with computers! I'm just a clown who is trying to take care of his car! I still have heaps to learn)
