Oz S2000 track 'hall of fame'
#501
Phillip Island (16/06/13) - 1:58.24 (with Dunlop Z2s, I/E, coilovers, BBK, 4.44 gears, 1.5 way LSD, 4 point rollbar, stripped and replaced soft top with hard top (full interior otherwise!), CR wing)
http://racing.natsoft.com.au/6358910....89Z/Result?32
#502
HOF updated with the times from the references above.
63.13 - Just reading it there doesn't show my fastest time
HOF updated with the 63.34 listed at Natsoft. What timer/reference do you have for the 63.13 mentioned?
Barbagallo - Long track: 1:14.74, Short track: 1:03.16
HOF updated.
1:47.35 @ Winton 3km, 20/4/13 H Nationals 2013
HOF updated.
Winton: 1:44.59, Ohlins DFV, oem wheels and potenza s02, 20/4/13 H Nationals 2013
HOF updated.
Winton: 1:39.29, Intake/exhaust, Eibach pror2 evasive spec, GT Wing, a050 semi slicks, 1:39.29, 20/4/13 H Nationals 2013
HOF updated.
on the note of timing, what is sufficient? For instance, I use racechrono + 10hz GPS receiver to do my own datalogging. Can I pull times of that for here or should it be a bit more official then that?
Any GPS timer is sufficient Daevilone. Though, if it's not on Natsoft, then please provide a capture/dump from the timer for reference.
from Wakefield 10/06/2013 - 1:11.310. Event: Circuit Club, mods: R-Specs + coilovers + intake. also, 1:10.26 the next session without official timing - timing done on my phone and external GPS that agreed with the above lap down to 1/100th
HOF updated with 1:11.31 Daevilone. Though, if you can post capture/speed trace of the 1:10.26 time from racechrono, then I'll update the HOF with that time.
Clubman - 62.74 Same mods as before just with RS3's instead of RSR's
HOF updated.
Winton - 1:35.49 = Vyets, S2000 (with R-Spec Rubber + coilovers + FSB + BBK + I/H/E + 4.77 + GT Wing + rear diffuser + roll bar)
HOF updated. Congrats ... awesome time Vyets. You're over 2sec quicker than the next person in the HOF.
Winton (10/06/13) - 1:40.10 (with Dunlop Z2s, I/E, coilovers, BBK, 4.44 gears, 1.5 way LSD, 4 point rollbar, stripped and replaced soft top with hard top, CR wing)
HOF updated.
New pb at lakeside. 61.94 - setup still the same with the addition of a 4point roll bar.
Hi Thebob, I can't find find your time at Natsoft. I'm looking at the 15/6/13 time attack meeting, and there's no S2000 listed. Can you help? ... unfortunatelly the Natsoft links no longer work (since they 'refreshed' their site).
HOF updated.
HOF updated.
HOF updated.
HOF updated.
HOF updated.
HOF updated.
HOF updated.
HOF updated.
#503
I should probably update...
Sandown (25/5/13) - 1:29.64 (with Dunlop Z2s, I/E, coilovers, BBK, 4.44 gears, 1.5 way LSD, 4 point rollbar, stripped and replaced soft top with hard top, CR wing)
http://racing.natsoft.com.au/6365591....91C/Result?26
Winton (20/04/13) - 1:38.59 (with Hankook Z221s, I/E, coilovers, BBK, 4.44 gears, 1.5 way LSD, 4 point rollbar, stripped and replaced soft top with hard top, CR wing)
http://racing.natsoft.com.au/6365591...0.91D/Result?1
#504
Oops. HOF updated Aozora.
#505
David M:
I will have to add the addition of a 4 point roll bar to the description as well.
http://racing.natsoft.com.au/6355776...456.88Y/View?1
Position 7.
7 58 Bobby Blinco Bobby Blinco Hnda S2000 44 29 1:01.9414 0:02.6562
Position 7.
#506
David M:
Position 7.
Position 7.
I think the roll bar is more of a weight disadvantage than anything! But safety always
#508
I would have to agree performance wise you will probably lose as the chassis already feels quiet firm and all you are really adding is weight. But from a confidence point of view, it gave me a lot. Which as you full well know, that drops times all by itself.
#509
First post on here. Might as well make it an informative one
Wakefield Park (7/7/13) - 1:09.7 (Laptimer logged 1:09.4 in another session that was untimed)
http://racing.natsoft.com.au/6356208...424.88Y/View?6
Modification
- J's Racing style intake
- 70mm Titanium exhaust
- Haltech ECU
- Coilovers
- BBK
- Federal 595 RSR street tyres (265 and 285 tyres)
Stock aero and soft top
Modification
- Haltech ECU
- Coilovers
- BBK
#510
Originally Posted by aozora' timestamp='1373948422' post='22668205
What roll bar did you end up getting?
