***\\\ LS2Kitt ///***
Probably going to piss off a bunch of people but what the hell. lol
So here's my LS swapped S2000 and my build sheet Motor/Trans: LS1 5.7/T56 from a 01 WS6 Trans Am Induction FAST 102mm LSXR Manifold WARR 92mm Throttle Body 3.5" Carbon Fiber Intake Tube JLT Air Filter Fuel Fuel Safe 10g Enduro Fuel Cell Radium FSCT w/ AEM-1200’s Radium 12 Micron Fuel Filter Radium Fuel Pressure Regulator Radium Fuel Pressure Gauge Radium Fuel Level Sender Radium AN Fittings Russell’s AN Fittings Russell’s Black Fuel Line Holley AN Fittings Holley EFI Billet Fuel Rails FIC LS2 42lbs Injectors Valvetrain 243 TBSS Heads BTR Stage 3 Cam BTR .660" Dual Valve Springs BTR Steel Retainers BTR 7.400" Chromoly Push Rods COMP Trunion Upgrade Kit LS2 Timing Chain LS7 Lifters Bottom End Kings Bearings Kings Rings Melling High Volume Oil Pump Trickflow 25% Underdrive Pulley Headers/Exhaust Hooker Block Hugger Manifolds Speed Engineering 3” X Pipe Kit Vibrant 3” Ultra Quiet Mufflers Vibrant 3” Resonators Vibrant 3.5” Tips Vibrant 3” V-Band Clamps Mahle Manifold Gaskets ARP Header bolts Accessories Katech Billet Tensioner LSSimple Alt. Relocation Bracket TSP 1.9hp Mini Starter TSP Black 180amp Alternator OriginFab Catch Can OriginFab Coolant Overflow AlloyWerks/Hasport Motor Mounts ICT Billet Battery Tray Cooling Schmuckbuilt Radiator Schmuckbuilt Shroud & Fans Holley Steam Line Kit LS2 Water Pump Jegs Black Thermostat Housing 180° Thermostat ECU/Electrical/Wiring Ms3Pro EVO Full Stand Alone Aim MXS Strada Icon Display AEM X-Series Wideband x2 NGK Plugs Taylor 10.4mm Spark Plug Wires LSX Innovations LS1 Coil Brackets AlloyWerks Relocation Brackets MotionRaceworks USB Bulkhead Optima Yellow Top Battery Transmission McLeod RXT Twin Disk McLeod Billet Steel Flywheel Speedway T56 Remote Bleeder MGW short throw shifter Earl's Steel braided clutch line Earl's AN fittings Energy Suspension Trans mount AlloyWerks T56 Trans Bracket Rear End Import Muscle Camaro SS Diff Kit DSS Aluminum Driveshaft DSS 600hp Axles DSS 600hp Hubs w/ ARP studs 2012 Camaro SS 10 Bolt Diff. GM 3.91 Final Drive Gear Set Eaton Detroit Truetrac LSD Ratech GM Bearing/ Shim Kit Brakes Powerstop Calipers Stoptech Street Pads Stoptech Slotted Rotors Stoptech Steel Braided Lines Wilwood Clutch master cylinder 2000 Civic Si Prop. Valve Hardcore Bays ABS Delete/Tuck kit Chassis/Suspension KW V2 Coilovers Cusco 32mm Front Sway Bar Cusco 30mm Rear Sawy Bar Cusco Subframe Brace PWJDM Rear Lower Brace Hardrace Roll Center Adjusters SPC Adjustable Ball Joints ARP Extended Studs Wheels/Tires CCW LM5 18x9 +38 Nitto NT05 255/35/18 18x12.5 +32 Nitto NT01 315/30/18 Skunk2 Black Series Lug Nuts Interior Rockstar Garage DD Roll Bar Rockstar Garage Seat Belt Bar BRAUM Venom R Seats BRAUM 5pt Harnesses PCI Seat Mount (Driver) BuddyClub Rail (Passenger) Ballade Sports Aim MXS Bezel Custom 3D printed Bezel Inserts Sparco 330mm Steering Wheel Works Bell Hub Exterior VIS Top Secret CF Hood VIS Amuse Front Bumper Chargespeed CF Canards RockstarGarage Mugen CF HT Circuit Garage Rear Flares Carbon Fiber RX7 Side Diffusers 400hp 370tq https://cimg5.ibsrv.net/gimg/www.s2k...79ef9b1f4e.jpg https://cimg6.ibsrv.net/gimg/www.s2k...e2bb6c512b.jpg https://cimg0.ibsrv.net/gimg/www.s2k...e2e6c60ed1.jpg https://cimg2.ibsrv.net/gimg/www.s2k...8b5c7a046f.jpg https://cimg3.ibsrv.net/gimg/www.s2k...9612d90ea8.jpg https://cimg4.ibsrv.net/gimg/www.s2k...a38b9532fd.jpg https://cimg5.ibsrv.net/gimg/www.s2k...2c6960b578.jpg https://cimg1.ibsrv.net/gimg/www.s2k...288d5e2cfa.jpg https://cimg4.ibsrv.net/gimg/www.s2k...c16e405272.jpg https://cimg4.ibsrv.net/gimg/www.s2k...6b459ddde8.jpg https://cimg7.ibsrv.net/gimg/www.s2k...05a196b5d9.jpg https://cimg3.ibsrv.net/gimg/www.s2k...64ebee94ea.jpg https://cimg0.ibsrv.net/gimg/www.s2k...8f042c268d.jpg https://cimg3.ibsrv.net/gimg/www.s2k...e5b685700.jpeg https://cimg6.ibsrv.net/gimg/www.s2k...e1930cc9c.jpeg https://cimg7.ibsrv.net/gimg/www.s2k...3418e3192.jpeg https://cimg4.ibsrv.net/gimg/www.s2k...dfe667d48a.jpg |
Whats wrong with the F20C?
Get some NT-01s on the front to match the rears, A BBK, and take it to the track. This should be fun.
Originally Posted by ALBERTS2K
(Post 24816205)
I've had the car for 15yrs, 3 F20c's one being fully built/sleeved/CNC head and boosted. After the last one spun a rod after 2500 miles I wanted to try something else. It was either part the car out completely and buy a C6Z or LS swap with what I already had. |
(Post 24816212)
like these? lol I do have plans to get another BBK, unfortunately I'll probably have to change my wheel setup. the CCW's are not very BBK friendly https://cimg9.ibsrv.net/gimg/www.s2k...d36a1e85ee.jpg |
I think it's awesome, it must be a blast to drive! Do you know how much of a total weight gain you incurred?
Originally Posted by saving4one
(Post 24818234)
supposedly the aluminum LS motors only add 90lbs to the front end. most SC and turbo kits add around 50-60lbs so its not much more |
One day if you ever put that thing up to check the cross weights I would be interested how it looked. Also with tank moved behind the diff that has to mess with handling I'd think. But like everything, theory doesn't equate reality. Having owned boosted S2000 and a C6 Corvette; I get why you did this. Looks extremely clean.
Originally Posted by Ian300D
(Post 24818617)
When it comes to the handling, the tank relocation not so much but pushing the steering rack forward definitely makes the snap-steer worse. (ask me how I know) lol |
Very cool and looks well built. I'd be curious to see cross-weights too.
