** 2JZ S2K ** Build thread, its here.
#22
I thought I would start with the wiring harness and what needs to be added back on to make all the functions of the S2000 still there. This is what I have come up with.
Alternator Plug ( green ) 4-pin Black/Yellow : White/Green : White/Red : White/Blue
Alternator Plug that runs tot he fuse box for charging the car, and battery. Single Black wire
If I want to use the stock Coolant temp sensor I will have to run these wires, but I am sure the F20C and the 2JZ runs at different temps, so the gauge cluster readings may be off. I will have to look into that. Red/White : Green/Yellow
Reverse light on transmission Yellow : Green/Yellow
ABS sensor on transmission Yellow/Blue : Blue/White : Brown/Yellow
If I do retain the A/C I have to run one A/C fan clutch wire Black/Red
Starter Solenoid. Black/White
#24
I know this was done quite a bit a while back but what to call it now? S000pra? S2pra? S2kpra?
Anywho, GL with your build man. Can't wait to see it finished!
#25
" 2JZ wut " " 2JZ S2K "
We can call the car something, lol.
