Pass smog with High Flow Cat?
I'm just curious if anyone up here has passed smog with a high flow cat?
I just smogged my other car (Element) and the guy said they only check for codes and do a visual, so there's no need to worry about emissions testing.
I'm trying to decide between the BERK HFC and the Ballade Sports one that can use the OEM heat shields.
Thanks!
Thanks!
WilloW (02-17-2020)
WilloW (02-17-2020)
I had tabs welded onto my Berk high flow cat and fitted the OEM heat shields. Looked OEM under the car. A chunk of concrete under the car at highway speeds cracked the tabs and it rattled so the shield came off for now. Can easily fit the OEM shield well enough for a visual inspection by wrapping heat tape at each end of the cat thickly enough for a tight fit of the shields.
-- Chuck
-- Chuck
