Has anyone had problems with
Guest
Posts: n/a
I noticed this past week that when i braked hard, the oil light lit up. Took my car to firestone where i usually do the oil changes and found out i was 3 quarts low. What the hell?!?! howd this happen? anyone experience problems with Mobil 1 full synthetic high mileage? what could this be? anyways, im going to check my oil every week just to make sure im not losing oil. Its definitely not a leak because the underside of the car is clean. weird. btw: this is the first time i started using mobil1 high mileage since i hit 80k.
Either there is a leak or the brain childs at Firestone didn't put enough oil in it. ...2.5 quarts of anything is an awful lot to burn up. You would have seen it running through the exhaust.
I have been using Mobile 1 since 10k and I don't burn a drop of oil.
Edited-
Sometimes my vision is limited.
It appears that some other folks have had similar problems switching back and forth.....
https://www.s2ki.com/forums/index.php?showt...0&#entry3175764
I myself, wouldn't leave Mobile 1.
