how do you fix a cracked intake pipe?
so my friend has this ingen cold air intake and the a weld part has broken off. now the engine check light is on. so anybody know how to just fix that part of the pipe? i couldn't find a place would just sell me the pipe.
help :( |
Duct tape?
The CEL is probably just caused because air is leaking out. Duct tape will solve that problem. Eventually, you can get it welded - but if it's aluminum (it probably is) then it might not be worth the trouble and $$. You might just pick up any pipe off of an ebay intake. If you can find a perfect match, you can always get a straight section of pipe, hack all the pipes up, and just attach them all using clamps and those rubber hose things. I would personally start by calling injen. If they don't take care of you or atleast sell you that section, then i'd make a website called injenintakessuck.com and commit your life to getting people to visit it. That'll teach em... |
Originally Posted by minboost,Sep 19 2007, 10:39 AM
Duct tape?
The CEL is probably just caused because air is leaking out. Duct tape will solve that problem. Eventually, you can get it welded - but if it's aluminum (it probably is) then it might not be worth the trouble and $$. You might just pick up any pipe off of an ebay intake. If you can find a perfect match, you can always get a straight section of pipe, hack all the pipes up, and just attach them all using clamps and those rubber hose things. I would personally start by calling injen. If they don't take care of you or atleast sell you that section, then i'd make a website called injenintakessuck.com and commit your life to getting people to visit it. That'll teach em... thanks for your input ;) |
You can try the JB-WELD.It's available at any AutoParts stores.
you can TIG weld it, most muffler corner store will not have tig weld, call around it's not hard.
JB weld will do if you are cheap, the intake pipe has little pressure so the weld doesnt need to be strong edit: depends on the part of the pipe, you might or might not want to use cold weld |
