Rockstar Garage. special services & maintenance Thread
[size="4"]Hours Of Operation
Monday - Saturday 9am to 6pm
***appointments available outside of business hours.
[/size]
[size="4"]Rockstar Garage has been operating since 2011. specializing in all things s2000. We do everything from simple oil changes to complete engine builds. we offer paint services, and race prep. our team consists of experienced time attack and race drivers as well as a 10+ year Honda Master Tech who also has a lot of experience with some of the fastest honda race cars in California.
Our race program has allowed us to develop good relationships with many trusted aftermarket companies. These relationships have given us access to great pricing on parts which we pass down to our customers! We have more experience with different brands than most, allowing us to give you an educated recommendation for the parts you are considering putting on your S2000.
The following prices pertain to S2000's. For other makes and models, please contact us directly at (909)766-0774.
[size="5"]TRACTION[/size]
We stock most popular S2000 spec street/track tires!
Bridgestone re71r / Hankook RS4, z214, Hoosier R7, Federal RsRR etc
We also carry all other major tire brands for truck and your daily
Tire Dismount
$10ea
Tire Mount
$10ea
Tire Balance
$10ea
TPMS Replacement
$5ea
Tire Repair
$25 each (approved repair)
ALIGNMENT
$80 factory spec
$100-$125 custom track specs
$300 corner balance/ 4 wheel alignment
[size="5"]SUSPENSION[/size]
Coilover install
$200 on most
Coilover height adjustment
$25 Per Corner on most
Lowering springs installation
$250.00 on most
$450.00 Swift Spec R springs and install
Sway Bar isntallation
$75 front
$50 rear
Half-shaft Spacers
$75.00
Blox spacers pkg price installed
$150
Front RCA installation
$100
Buddyclub RCA ( with camber adjustment)pkg price
$350
Rear ball joint isntall
$150
Buddyclub ball joint pkg price
$300
Rear axles install
$250
Insane Shafts 500hp axles pkg price
$700
Wheel bearing replacement
$375 ea/ corner (INCLUDES OEM hub & bearing)
extended ARP studs also available.
[size="5"]AERO & EXTERIOR[/size]
APR wing isntall
$100
GT Wing install
$125.00
APR splitter install
$150
Custom race splitter and install
$750+
Hardtop installation
$100 for all RSG, Mugen, Amuse and Honda tops
$150-200 all other brand hardtops
Softtop removal
$300.00
Soft top replacement
$400 (used complete unit)
Canvas replacement
$500-600
OEM pkg price soft top replacment
$1750 includes all OEM parts, straps, fastners etc
[size="5"]ENGINE[/size]
OEM air cabin filter/installation
$30
OEM air filter/installation
$45
Motul fluid, OEM filter & gasket
$95
OEM Honda fluid, OEM filter & gasket
$75
Valve adjustment w/ Honda gaskets
$150
Injector flow test and rebuild
$180
AC belt
$80 OEM belt
Short ram intake install
$50.00
Cold air intake install
$100
Plenum style instake install
$150 (pwjdm type)
Exhaust removal/installation
$50.00 on most
Header removal/installation
$100.00 on most
Motor Mount install
$250 - Installation + parts
$500 - OEM mounts included
[size="5"]TRANSMISSION[/size]
Motul fluid/OEM gaskets
$80
OEM Honda fluid & gasket
$70
Clutch replacement
$500.00 + parts
Flywheel machining
$50
Clutch Master/slave combo
$380 (OEM Honda parts and Fluids)
COMPLETE Transmission Rebuild
includes removal/ teardown and rebuild
replacement parts are additional
$750
[size="5"]DIFFERENTIAL [/size]
Motul fluid with OEM Honda gaskets
$60.00
[size="5"]COOLING [/size]
Coolant Exchange
$125 Honda Coolant
$150 Motul MoCool (water wetter is mandatory for race)
Radiator install
$80+ flush and fill
oil cooler install
$150 + parts and fluids
[size="5"]BRAKES[/size]
Front pad/rotor replacement
$75 + parts
Rear pad/rotor replacement
$75 + parts
Rotor resurface
$15 each
Brake fluid flush and bleed.
Motul RBF600
$125.00
SS Braided Brake line install
includes flush and Motul fluids
$250 + SS lines
[size="5"]SAFETY[/size]
RSG roll bar install
$450[/size]
