Broken valve cover bolt
I was installing an intake on my friends gs350, and the mounting bracket goes on the valve cover bolt. While putting the bolt back on, I over tightened it and it snapped off :banghead:
How can i remove the remaining part of the bolt? It is too low to grab with a vise grip. The hole goes through if that makes any difference. Thanks in advance for your help! |
what year, what engine?
its a 2007
It is the standard v6 engine in the gs350 |
You need to get a bolt extractor bit. You attach it to your drill, set it in reverse & drill a small tap hole. You then flip the bit & extract it with the tool. Cost around $15-$20 at a hardware store.
I once stripped the head of an allen on my steering wheel/quick release setup & this is what I used to remove the stripped bolt head. Same principle for broken off head, as long as there is surface to work on. |
Can you just pull the valve cover then grab the remnants of the bolt?
Removing the valve cover on this car would be a lot of work. There is so much stuff on top of it, i wouldnt know where to begin haha.
Thanks for the help. Looks like i'll have to use an easy out. I was really trying to avoid it though :cry: |
do yourself a favor and dont buy the black and decker bolt extractors. i broke three in a row while using them properly and trying to extract a fairly non rusted bolt. i went and bought a good set and it worked like a charm.
good luck. |
