Friend and I Building an 03 WRX STI Together. Any Recommendations?
Hey guys, hope you're all doing well and staying warm (cold as hell even here in Texas right now).
My friend is picking up an 03 STI shell with (what I'm assuming) is a functional 6sp transmission and drivetrain. So far our plans are to build up an EJ25 block/EJ20 head hybrid engine with aftermarket pistons to allow for valve clearances and lower compression for more boost, but I was wondering if anyone here is more familiar with Subarus or had any other input. I know that some of the EJ engine series were prone to head gasket failures and oil starvation around the piston rings, but I don't really know what to do about that outside of using fresh new gaskets and making sure everything is sealed and seated properly. I'm also curious as to if the stock ECU can be tuned, or if it'll require a chip/aftermarket ECU, etc... I'm still poking around on some NASIOC and some other Scoob forums, but I value the opinions of a lot of people here on S2KI so I was curious if anyone has experience with these platforms. Let me know what you guys think, or if there's any other recommendations on the build :) We're going to try to keep it relatively cheap, this car will mostly just be used for general hooning and shenanigans. |
Originally Posted by Chance S2K
(Post 23528702)
My friend is picking up an 03 STI shell with (what I'm assuming) is a functional 6sp transmission and drivetrain. So far our plans are to build up an EJ25 block/EJ20 head hybrid engine with aftermarket pistons to allow for valve clearances and lower compression for more boost, but I was wondering if anyone here is more familiar with Subarus or had any other input. I know that some of the EJ engine series were prone to head gasket failures and oil starvation around the piston rings, but I don't really know what to do about that outside of using fresh new gaskets and making sure everything is sealed and seated properly. I'm also curious as to if the stock ECU can be tuned, or if it'll require a chip/aftermarket ECU, etc... I'm still poking around on some NASIOC and some other Scoob forums, but I value the opinions of a lot of people here on S2KI so I was curious if anyone has experience with these platforms. Let me know what you guys think, or if there's any other recommendations on the build :) We're going to try to keep it relatively cheap, this car will mostly just be used for general hooning and shenanigans. Here is what I would do: Rotated mount turbo kit with Front mount intercooler - Opens many door for turbo options and removes heat soak. Built block and motor with good fasteners and seals. Meth injection. Tuning. Nothing else really needs to be touched. On a stock motor, the rotate mount turbo kit will allow 400 AWHP. 450+ can be had with Meth injection on a stock block. A VERY good tune is needed to run these numbers. Ringland issues really only affected the 07/08+ models. Head gasket failures are more common on the N/A motor, not so much an issue with boosted motors. I had 160,000+ miles on a stock block 06 STi and no issues. |
I'd say stay away or move on... :banghead:
Originally Posted by mosesbotbol
(Post 23528926)
There wasn't an 03 STI, you sure you don't mean 04?
(Post 23528702)
Which used to be worth ~200 dollars and with some free software could datalog and tune yourself, it has full ECU control. You might have a tough time finding a tuner that will use the tactrix though.
Originally Posted by Sebring AP1
(Post 23528961)
Originally Posted by King Tut
(Post 23528996)
Originally Posted by Aurex
(Post 23529003)
(Post 23528702)
(Post 23528702)
(Post 23528702)
(Post 23529011)
I'm sure we'll figure something out; I doubt we'll be going over ~350AWHP. May even try tuning it ourselves depending on how this all plays out.
You better have a good understanding of Subaru's and their software or I guarantee BOOM! |
(Post 23529011)
