AAA's premium fuel study
My wife's NA Mazda 3 does not care what you put in it and gets about 39 mpg just about every tank.
vader1 (12-28-2017)
I see Chuck's post above. Pardon my dumb question, but, what exactly is the Honda spec re gas for the S? Where is it stated? And, is it a "recommendation," or is it "required?" It all seems a bit murky.
Your Honda is designed to operate on premium unleaded gasoline with a pump octane number of 91 or higher. If you are unable to find premium unleaded gasoline, you may substitute an unleaded regular gasoline. The engine will compensate for the lower octane, but you may notice a slight decrease in power as a result. We recommend gasolines containing detergent additives that help prevent fuel system and engine deposits.
I used 87 octane on my cammed Integra LS (non-VTEC). It had the stock low 9.2:1 compression so no reason to switch up to 91+ as that would have just led to a less efficient burn, not more. Was making 100hp/L and never had an issue.
Never understood why most stations sell 87, 89, and 93. Most cars I've owned which ask for higher octane ask for 91+, 89 is essentially useless and 93 is overkill. Anyway, my $.02 on the matter....
The reason cars only require 91 is because some states (like California) don't get 93. I have noticed a trend of high performance cars being tuned for 93 recently which means those of us without access are probably getting slightly less power than advertised.
Switched to 91 by accident in my 2005 Civic several years ago. Car immediately ran smoother and made less noise while getting slightly better MPG. Haven't used a lower octane since then, regardless of whether or not the motor requires it.
s2kadrenalin
03-02-2010 07:22 PM
