More HP for Miata? Yes please.
I"m excited to see where this goes. In 10 years, the used ND market will be awesome. My s2k will be 22 years old by then and likely a giant pain in the ass to maintain if I still have it.
I can see an ND-RF in my future. Yeah, it's an extra 110 lbs. over the convertible, but if they put the sky active motor in there, i'm sure it will still be a fun 2400 lbs. car making ~190hp. It'll be like a poor mans slowtus that's reliable that doesn't get automatically get totaled due to an off track excursion that damages the clam shell made out of crystal and gold leaf.
Agreed. If you read articles about the development of the car, decisions were made every step of the way to shave weight. Add more power, then you have to beef up the tyranny and rear end. Driveshaft, halfshafts, etc. With more weight, then beef up the suspension. Then you have to go from 4 lug to 5 lug wheels. Before you know it, you've added a few hundred pounds and it's a totally different car. You won't see a 2300lb miata with 240hp anytime soon.
The drive train and lug design is not going to matter with an extra 26 horsepower. The limit on those parts is more a function of grip, so weight of the car and type of tires. The power is also going to come in the form of a longer torque curve, not a fatter one...so there will not be significant additional force really at play on these parts.
You guys are forgetting brakes as well. More power = more energy = need bigger brakes. I just bought some new rotors and holy hell they're heavy.
My #1 deterrent from getting an Elise...
I dunno - you used to see 3,000+lbs Accords with 4-lugs all the time.
My point is that if people think a minor power bump is enough to change the lifespan or safety of these components that it must be built like a porcelain doll with only 155 horsepower as is.
Im building a 400 horsepower 240 Z and its gonna run 4 lug on very grippy tires.
Exactly.
Yeah, they might up the brakes a bit, and it could add a few pounds to the engine, but I would bet that the total weight gain is less than 50 pounds if even close to that. We are talking about adding 27 horsepower.
Don't forget that the old Fox body 5.0 Mustang had 4 bolt hubs as well!
Unfortunately designing production components isn't like modding a car at home. Going from 150hp to 190hp will make numerous components fall under the required safety factors. It doesn't mean it will fail, but it will be under the safety factors they are required to design to. (I'm a mechanical design engineer in aeronautics)
They'll have to analyze the hubs and axles being launched by reckless drivers and it will not react nearly the same as a 150hp/150lbft car.
Also, a bolt holding the entire truck means nothing. That is not the load case that bolt is designed for, it's just a neat marketing technique.
