Need general info on diesel truck.
Hi,
My brother wants to get a used diesel truck for his waste removal business. Mostly waste from housebuilders.He's been looking at Ford F250 from 2004, 2005, 2006. I don't know much about diesel trucks, only info I was told is that they're noisier, has much more torque and less horsepower when compared to a gas truck, not every gas station has diesel, and diesel engines require more maintenance and is more expensive to fix if something goes wrong. I'd appreciate any info/advice you guys can provide. I'm not even sure he needs a diesel truck, HD gas trucks would be fine I suppose.
Thanks!!!
Thanks!!!
Site Moderator
Generally they are reliable as long as they are well maintained. Does he need to tow something? If not there isn't really a good reason to pay the premium for a diesel truck as he could likely get a newer gas truck with lower miles. I would definitely buy a diesel HD truck over any of the gas powered ones. Better MPG and better towing. You will have to do some research on which truck is best from those years as I am not sure who builds the most reliable (and each company ford, chevy, dodge all have their fanboys).
Yeah he will definitely be towing stuff to waste disposal sites from homebuilding projects. Waste may include lumber, roofing materials, scaffolding, bricks, concrete, rebars,....
The high torque, lower power ratings of a diesel are for heavy duty pulling power. The don't accelerate as fast as the bigger engine gas pickups, but they will pull a house. When you need to start from a stop with a really heavy load, that is where the diesel shines and they do it all day long. There is a reason semi trucks are diesel. For what it sounds like he wants it for, he knows what he is doing looking for a diesel. I have a friend who loves his Duramax diesel. Don't know the difference between something made by Ford vs. a Cummins.
Justapickup (08-03-2018)
If looking at used trucks from that era, I would go with a dodge and the 5.9 cummins. Only buy a truck with documented maintenance history, and it should last for a long time.
Never been a problem for me. Diesels have bigger fuel tanks and a lot of range.
Not sure why no one has made a turbo diesel hybrid yet. It seems like the best of both worlds for towing. Both are torque monsters from a stop and are sound like they would be great for gas mileage.
On paper, it sounds like a win win.
Electric batteries are very heavy and ultimately they reduce your payload/tow rating for a vehicle, as you have to add the weight of the batteries to the overall load. It's just not worth it on a pickup meant for towing/hauling large loads.
So I have owned many diesel trucks in the past All makes and models. The 2003-2007 F250/350 has the 6.0l powerstroke. While its a fun motor when tuned it is not reliable unless its deleted and studded since the headgasket likes to go. Usually runs around $8k or more to do the job. The best year F250 he can find is probably a 99-2002 with the 7.3l powerstroke. They were built like tanks if taken care of. The other popular engine is the 5.9l cummins only issue is that dodge trucks from the era are terribly built. One thing to consider is that diesels are expensive to maintain and repair the newer ones are even worse. With that being said I loved driving them even though they may make me look like a wanker as its the proper way to have a truck
