Need Help: Non-S2000 related
Old 03-02-2003, 04:02 PM
RoBD305's Avatar
Default Need Help: Non-S2000 related
I need some help especially from those who know about cars in particular transmissions. My 2nd car a MB C220 is having problems. The car is able to start up and everything but the minute I move the shiftgate into Reverse, the car dies on me. When I start the car from neutral and move it into drive, its ok. When I start from neutral and move to reverse, the car dies again. This sounds like a transmission problem to me. Anybody have any ideas or suggestions. I appreciate all your help> Many Thanks. Robert
Old 03-02-2003, 04:29 PM
Type S Zero's Avatar
does the engine die right away as soon as you get it into R like if you had turned off the key ?
(i'd suspect a short in the electrical system in that case)
or the engine seems to get a force applyied to it and then dies because of that ?
(mostly a mechanical problem related in that case)
do you hear any noise when you take it into R ?
Old 03-02-2003, 05:19 PM
cyman33's Avatar
I would check my fuse box and make sure all the fuses are in good shape....Just in case
Old 03-02-2003, 05:33 PM
HondaGal's Avatar
Moving to Car Talk
Old 03-02-2003, 07:20 PM
Javelin360's Avatar
Might be a problem with the reverse interlock switch.
ralper
03-06-2019 02:12 PM
zbt1985
09-28-2012 02:08 PM
Silvia2Nv
24
05-19-2009 06:01 AM
CTECHs2k
05-01-2008 07:58 AM
Quick Reply: Need Help: Non-S2000 related
