Go Back  S2KI Honda S2000 Forums > General Interest > Car Talk
Reload this Page >
Sequential Gearboxes
Notices
Car Talk Discussions and comparisions of cars of all makes and models.
Old 06-01-2017, 04:53 PM
Liked 60 Times in 50 Posts
Awesome!
TheDonEffect is offline
Old 06-02-2017, 12:44 PM
Liked 12 Times in 11 Posts
Originally Posted by RedCelica View Post
Do it!
here's how it works with paddles
Driven is offline
Old 09-20-2018, 09:43 AM
Liked 0 Times in 0 Posts
Originally Posted by Driven View Post
It's a Quaife, so they only provide the back half of the box, meaning, the provide the gearset, the shift drum, and the back half of the case, along with the shifter and cable. You need to provide the reverse gear and shaft, a diff and diff bearings, and bellhousing with
If you buy that thru a North American distributor, they list it as $8800~.
I bought mine from Momentum Motorsports in the UK, they list it as 4950gbp... with Brexit, the USD:GBP is insanely good, and I bought my gearbox at $1.21:1gbp. Add in shipping and import tax, and it was roughly $7000.
If you have a K series gearbox, especially one with a LSD diff, then your costs are done.
If you don't, then add in costs for a bellhousing, diff, etc, etc.
She looks pretty though:
Sorry for this newbie question: with quaife do you have to press the clutch pedal or not? I’m wondering this because I’m going to buy a sequential for my ‘09 S2000. Thanks. Very interesting thread
Ale
alessios2k is offline
Old 09-21-2018, 09:25 AM
Liked 19 Times in 19 Posts
I thought the clutch was for downshifts only.
rwheelz is offline
Old 09-21-2018, 10:19 AM
Are you sure rwheelz?
Old 09-21-2018, 10:26 AM
Liked 63 Times in 55 Posts
And I thought the clutch was only for starting off from a rest. We need Driven to clarify!
JonBoy is offline
Old 09-22-2018, 07:40 AM
I think that is how most sequentials work. I just watched the vid and he is clutching downshifts. Driven do you still have to heel/toe?
NICE VID BTW! I wonder if I can put the same setup into my MR2 Spyder. K-swaps are common now and it would weigh in about the same. I have seen a turbo K24 swap, but not with a sequential gearbox. What sized tires do you run on that noble?
rwheelz is offline
Old 09-27-2018, 08:52 AM
Ale
Really depends on what GCU you use for the gearbox.
Ultimately, you're trying to release some tension on the dogs so they can be disengaged for upshifts/downshifts.
Upshifts: Easy... you're already on the throttle, so you need something to cut power for a split second so the dogs release tension and you can shift.
Downshifts: More complicated because you can't just cut power, since you've already braking and shouldn't be on throttle. So, you can clutch in and shift... or less smooth, blip the throttle. The GCU COULD control downshifts, but it becomes a bit more complicated.
Heel/Toe your downshifts isn't necessary... you could, but you're more likely to mess things up.
Technical crap
How the whole system works with the Geartronics is it uses the GCU, a load cell (either a shift knob or inline load cell attached to the shift cable), and a potentiometer (mounted to the shift drum of the gearbox, either magnetically or physically).
Process while upshifting:
1. On throttle, you pull on the shift knob which activates the load cell.
2. Load cell tells the GCU that you want to do something.
3. GCU is connected to the coilpacks, so it cuts power to the coils
4. You yank on the shifter to grab the next gear
5. Potentiometer rotates and tells the GCU that the gear shift drum has rotated x degrees
6. GCU sees the shift has been completed, reapplies power. If you fail to complete the shift, the GCU will reapply power after a set parameter (mine is 500ms).
7. You giggle!
KPro can kind of achieve the same effect as the GCU, but uses fuel cut instead (less good). Standalone ECUs have options too... but it seems a lot just run with the GCU to keep the systems separate.
For paddle systems, I believe the downshifts are managed thru the GCU, so using the clutch is only necessary when starting/stopping ...
A few spyders have done it. Just mounts, axles, wiring, and custom exhaust manifold.
Driven is offline
Old 09-27-2018, 10:54 AM
Thanks Driven you're the Man!
Old 10-03-2018, 03:19 AM
UK Moderator
Liked 84 Times in 82 Posts
Some Quaife experience in this thread: https://www.s2ki.com/forums/uk-irela.../#post23772826
lovegroova is online now
jeffbrig
Car Talk
54
03-30-2016 10:05 AM
spectacle
06-18-2013 10:01 AM
GT Motoring DC5
06-07-2008 05:46 PM
AirborneS2K
09-17-2007 12:46 PM
s2konroids
03-11-2007 01:34 PM
Quick Reply: Sequential Gearboxes
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
