U.S. spec CR-Z Exclusive test
http://i488.photobucket.com/albums/r...r/GoldCr-z.jpg
It handles! But thats about it. :confused: http://www.roadandtrack.com/tests/car/u.s....2011-honda-cr-z 2011 Honda CR-Z List Price -est. $20,000 Curb weight est. -2560 lb. Weight Distribution -62/38 Wheelbase -95.8 in. Length -160.6 in. Width -68.5 in. Height -54.9 in. ENGINE Type -alum. block & heads, dohc 4-valve/cyl inline-4 Bore x stroke -73.0 x 89.4 mm Compression ratio -10.4:1 Horsepower (gasoline engine) 111 bhp @ 6000 rpm (combined w/ elect. motor) 122 bhp @ 6000 rpm Torque (gasoline engine) 106 lb.-ft. @ 4800 rpm (combined w/ elect. motor) 128 lb.-ft. @ 1500 rpm Fuel injection elect. seq port Recommended fuel unleaded Transmission CVT CHASSIS & BODY Layout front engine/front drive Body/frame unit steel Brakes, f/r vented disc/disc, ABS Wheels cast alloy, 16 x 6J Tires 195/55R-16 Steering rack & pinion, elec. pwr assist Suspension f/r MacPherson struts, tube shocks, coil springs, anti-roll bar/H-shaped torsion beam, tube shocks, coil springs FUEL ECONOMY City/Highway 36/38 mpg Fuel capacity 10.5 gal PERFORMANCE 0-60 mph 10.5 sec 0-100 mph 30.0 sec ΒΌ-mile, sec 17.6 sec @ 80.1 mph http://i488.photobucket.com/albums/r.../SpoonCR-Z.jpg Check out the Spoon CR-Z test drive to make yourself feel a little better. Its A LOT quicker. Its cool and all but I'm guessing the Fuel Efficiency goes out the window. http://www.roadandtrack.com/tests/car/worl...oon-sports-cr-z |
I think its the same articles posted here:
https://www.s2ki.com/forums/index.ph...c=777473&st=75 |
Crap. Thanks, Spinner. I missed that. Anyhow, I'm shocked at how painfully slow the car is.
This thing is about as fast as my Mitsubishi Mirage from over a decade ago. Probably getting so much praise for it's handling because of it's low weight by todays standards.
So much potential went right out the window. This car with a k20 would have been PROPER.
What a cute car!!! :D
Don't forget it was with the CVT, which is quite a bit slower than the 6MT. Other tests put this car at a smoking 0-60 in 9.3s with the manual transmission.
!!!!!!!!!!!!!!!!!!!!!!!!!!! Are you excited now? :D |
From NSXs and S2000s to this crap!!!! No more Hondas for me.
HAHAHAHAHAHA
