2005 NFR AP2 - Here We Go Again.....
Old 01-15-2019, 05:38 AM
J-Speed Inc.'s Avatar
Did some maintenance work on the car this Sunday:
- Replaced the cabin air filter (see picture of old one below)
- Oil change with synthetic Mobil 1
- Transmission fluid replaced with Torco RTF synthetic
- Clutch delay valve removed
- Stainless clutch line installed
- Clutch fluid flushed and bled. Old stuff was pretty gross
Need to get the swirls removed from the rearview mirrors. Going to try various compounds I have, if none of that works I bought some flexible adhesive-backed mirror plastic I could stick over the existing glass. Also need to replace the rear diff fluid and brake fluid.
Old 01-16-2019, 03:44 AM
abenson's Avatar
What method did you use to remove the clutch delay? I’ve seen people replace the slave altogether and I’ve seen a method that looks a little more tedious.
Old 01-16-2019, 04:35 AM
I Dremel'd a slot into the area around the snap ring to be able to get a small screwdriver underneath one end of it, then pry it out. I tried using two picks, that didn't work. Others have drilled a hole near the ring to be able to get a pick in the area, but the slot was the best method.
https://www.s2ki.com/forums/s2000-un...emoval-789870/
There's no need to cut the slot as deep as in this picture, just do it deep enough that you can manipulate the snap ring.
Old 01-16-2019, 08:23 AM
Chuck S's Avatar
Received 1,133 Likes on 996 Posts
Seems like all our cars have a cabin air filter that looks like that when we buy used. Makes me wonder what my other cars filters have or if they even have one.
-- Chuck
Old 01-16-2019, 05:26 PM
RedCelica's Avatar
Well glad to see you back in the saddle again, Josh. You sure do love your NFRs
Old 01-17-2019, 04:38 AM
I would have thought you learned that it's the fastest color by now....
mrxchris
Automotive builds
33
08-30-2020 09:34 AM
LAp2Eleven
Automotive builds
08-25-2017 04:01 PM
StanW
09-29-2015 07:32 AM
dialodee
03-10-2009 12:40 PM
Quick Reply: 2005 NFR AP2 - Here We Go Again.....
