Did some maintenance work on the car this Sunday:
- Replaced the cabin air filter (see picture of old one below) - Oil change with synthetic Mobil 1 - Transmission fluid replaced with Torco RTF synthetic - Clutch delay valve removed - Stainless clutch line installed - Clutch fluid flushed and bled. Old stuff was pretty gross Need to get the swirls removed from the rearview mirrors. Going to try various compounds I have, if none of that works I bought some flexible adhesive-backed mirror plastic I could stick over the existing glass. Also need to replace the rear diff fluid and brake fluid. https://cimg3.ibsrv.net/gimg/www.s2k...4154c8d60d.jpg |
What method did you use to remove the clutch delay? I’ve seen people replace the slave altogether and I’ve seen a method that looks a little more tedious. |
I Dremel'd a slot into the area around the snap ring to be able to get a small screwdriver underneath one end of it, then pry it out. I tried using two picks, that didn't work. Others have drilled a hole near the ring to be able to get a pick in the area, but the slot was the best method.
https://www.s2ki.com/forums/s2000-un...emoval-789870/ There's no need to cut the slot as deep as in this picture, just do it deep enough that you can manipulate the snap ring. |
Seems like all our cars have a cabin air filter that looks like that when we buy used. Makes me wonder what my other cars filters have or if they even have one.
-- Chuck |
Well glad to see you back in the saddle again, Josh. You sure do love your NFRs :p
I would have thought you learned that it's the fastest color by now.... :)
