Go Back  S2KI Honda S2000 Forums > North America East > Carolinas
Reload this Page >
Help with valve cover gasket
Old 02-26-2018, 07:42 AM
Default Help with valve cover gasket
Hi there! Anyone local to the Wilmington NC area that can help me with a valve cover gasket replacement? I'll do all the work but its my first time and I don't want to mess anything up.
Hs2ktc is offline
Old 02-27-2018, 06:49 AM
CoolGuy094's Avatar
I'm not close to you, but if you do it yourself just be really careful not to torque the bolts holding the valve cover down too much. They need such little torque, and they will EASILY snap the heads off with too much torque. Been there, done that, several times over. Also watch the spark plug tube seals when you put the valve cover back on. Lube them up real good and make sure they don't get caught/tear on the top edge of the tubes.
CoolGuy094 is offline
Old 02-28-2018, 09:04 AM
Pinky's Avatar
Same here as what CoolGuy said. I am in Cary, NC. If you want to FaceTime with me or if the car is drivable we can do it at a Tech Day.
Why are you replacing it if you mind me asking? Mine was around 15 years old and still in good shape. Is it leaking or just replacing as part of recommended maintenance while doing other things?
Pinky is offline
Old 03-06-2018, 10:43 AM
Afterfire's Avatar
Im in Wilmington and can help as Ive done it before. Ill be happy to help. PM me since I dont check this part of S2ki often.
Afterfire is offline
Old 03-07-2018, 10:05 AM
When I took it in for a another issue the mechanic suggested it. I just want to be proactive.
Hs2ktc is offline
Old 03-08-2018, 03:44 AM
Chuck S's Avatar
Grab the maintenance manual off with web. Valve cover gasket info hasn't changed. Torque specs are in there.
-- Chuck
Chuck S is offline
john82389
06-20-2012 02:42 PM
s2jerris
09-20-2011 05:55 PM
vader1
05-18-2011 08:34 PM
dru5o4
02-04-2010 08:16 AM
ex-eclipse
05-01-2006 02:28 AM
Quick Reply: Help with valve cover gasket
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
