Please Help me Wire up my foglights
Old Jan 29, 2007 | 05:15 PM
nMeOnE's Avatar
Default Please Help me Wire up my foglights
I installed my EK foglights like 2 months ago and still haven't gotten around to wiring them up b/c I haven't got the slightest idea how to run the wiring that came with the kit nor do I know where to tap the fuse to install a switch
I can install a headunit with DCI with no problems at all!!! but for some reasons I just can't understand this freaking harness!
I just wanna see these baby work after all that hard work i put into installing these suckers!!!
Someone please help me!
BTW i'm located in the NCSU area.
Old Jan 31, 2007 | 09:45 PM
nMeOnE's Avatar
No suggestions?
Old Feb 1, 2007 | 08:20 AM
bluegas68's Avatar
Do you just need a source for power and ground? Is the switch a standalone, or are you utilizing an existing switch (i.e. wiring into headlights so they come on together)?
How many wires?
Also, does the documentation tell the amperage draw for the lights. Im assuming they are halogen, maybe 55W?
Old Feb 1, 2007 | 08:29 AM
nMeOnE's Avatar
I'm gonna utilize an existing switch so they would be on when my tail lights are on that way the install would be easier on me. I'll post a pic of the harness soon.
Old Feb 1, 2007 | 09:00 AM
bluegas68's Avatar
How many wires are coming from that relay? The shadow is messing with my eyes
Old Feb 1, 2007 | 10:02 AM
nMeOnE's Avatar
4 wires
a white one that has a fuse, a black one which i know is ground, a red one and a blue one
Old Feb 1, 2007 | 10:14 AM
bluegas68's Avatar
where do the 2 brown(?) plugs go?
Old Feb 1, 2007 | 10:17 AM
nMeOnE's Avatar
one of the brown which contains the red wires goes into the foglight. I have no idea where the blue one goes
Old Feb 1, 2007 | 10:27 AM
bluegas68's Avatar
ok...i need to know which wire is on which relay pole (should be numbers like 30, 87, 85, 86) and you are, or are not wanting to use the switch that is pictured?
The documentation does not say anything about the blue wire (w/ plug)?
Old Feb 1, 2007 | 11:15 AM
bluegas68's Avatar
OK...i just looked at what you have. I wasnt aware this was factory stuff. It looks like you are supposed to have 2 harnesses. Is that correct?
