What's on the TO DO's list for the winter? I don't have much. Brake bleed, might try and re-wrap the hood and should that go well and it looks FAR better with a fresh wrap, I might continue around the car.
Just going to be happy driving her with a new stereo, fresh fuel filter, and cleaned injectors!
Just installed new OEM front rotors and pads and greased slide pins. First time doing myself. Great DIY project, and brakes feel fantastic now. Small leak in my clutch master cylinder so that’s next. Hope you consider having a tech day this spring.
Man, I need to jump on here more often! I just finished swapping out entire calipers for a customer. I should have taken pictures while I did it! I will probably zip one of the tires off and snap a picture since she's still up in the air.
Yeah, I can totally do a Tech Day this spring. What should we put on the list? I will start a new thread! What month are you thinking?
If the clutch Master is leaking a little, keep swapping out that fluid! It takes only a tiny bit to fill her up. Just suck out the old put in fresh. Do it often! It should clear that leak up in no time flat. It's apparently a thing that if it gets dirty fluid it will leak more and more.
If you do end up swapping it out, save it and give it to me, I want to take one of them apart out of curiosity.
