Tire rotation
Tire rotation
Hey guys, I need to have my tires rotated (meaning taken off the rim and flipped), wheres a good place to go in the Raleigh area?
I would like my rear brakes looked at as well as I think it might be time to replace the calipers but want a second opinion.
Thanks
Thanks
I think most of us can vouch for Performance Chassis in Cary. Solid shop, not the cheapest, but top notch. Just got back from there today actually from getting an alignment.
Rotating tires? Are they wearing unevenly? Maybe an alignment is in order. I haven't had an alignment done in probably 50-60K! Tires always wear evenly and drives dead straight.
Sad part is that I never have done this as the tires never live long enough to wear unevenly. Either that or my cornering evens them from the camber!
When I got the car, the calipers were in bad shape. I had to replace the fronts but I only rebuilt the rears. They are starting to squeak a little and I think they are sticking a little. I usually try to rotate them every 5k miles or so. The fronts have been on for around 9k, the rears I replaced about 4k miles ago.
Thanks for the suggestion, I will give them a call next week.
My rears are definitely wearing unevenly, but the fronts aren't. I got an alignment done when I replaced all 4 about 9k miles ago, and my rears wore out after about 4k. Going in for a rotation tomorrow.
I will probably get an alignment done again when I switch tires in a few thousand miles.
I think I'm going to switch from Direzza ZII's to Bridgestone RE-11A's next time. Do everyone else's rear tires wear that much faster?
